FTP login failing
- Everything else
- Re: FTP login failing
FTP login failing
01-08-2009 12:07 PM
I've had Plusnet boradband for over a year now but only recently decided to start using the web space. However, I can't log in to the FTP site to upload files. I'm connecting to FTP over a Plusnet broadband connection, using the same user name and password as I do to get into the members' centre, but I get '530 Login incorrect' every time.
Is there something I'm supposed to do to get this to work?
Thanks in advance.
Thanks in advance.
Message 1 of 4
(1,303 Views)
3 REPLIES 3
01-08-2009 11:58 PM
Try: ftp://username:password@ftp.plus.net/htdocs/ with Internet Explorer v6 not you must keep " : "
I hope this helps.
I hope this helps.
Message 2 of 4
(394 Views)
02-08-2009 6:51 AM
Altitude747: I have had a quick look over this and it looks like there is an issue with the login to the ftp server. So that we can have a good look at this for you can you raise a question on your account using the help assistant on the member center?
Message 3 of 4
(394 Views)
08-08-2009 9:06 AM
Just come back to this and lo and behold, it's working now! I hadn't yet raised a question on my account, but someone must have tweaked something behind the scenes -- thanks, whoever you are.
Message 4 of 4
(394 Views)
