FTP login error 530
randomcastle
FTP login error 530
I appear to have Standard Webspace, but have never used it til now. All attempts to access it via FileZilla meet with the same response - error 530. I'm certain I'm entering my username & password correctly. Previous posts on this subject seem to suggest this is something Plusnet personnel can fix. Any one out there?
5 REPLIES 5
VileReynard
Fixes: 20
Re: FTP login error 530
Invalid user/password.
Mav
Fixes: 515
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
randomcastle
Could you be a little more helpful. Such as, how might I reset the password for website login
RPMozley
Fixes: 13
Please ignore VileReynard's comment. You will have to wait for @bobpullen to pick this up, as he has the expertise required to help in this matter.
That's RPM to you!!
Fixes: 160
Superuser escalation
This topic has been escalated by one of the Superusers; please allow time for Plusnet to respond before commenting further.
Escalation does not imply progressing this matter will be given priority, nor that a different outcome will result.
Reason for escalation:  Request response
