FTP issues accessing website.
- Everything else
- FTP issues accessing website.
on
21-11-2017
6:23 PM
- last edited on
21-11-2017
7:30 PM
by
Mav
Unable to access my website www.armadajazz.co.uk
Originally with freenetname, then Madasafish
FTP worked up to 6-8 weeks ago
[tagging on to this old thread because I can't find any other similar topic]
Moderator's note by Mike (Mav): Changed thread title to reflect issue after split to own topic.
Re: FTP issues accessing website.
21-11-2017 7:30 PM - edited 21-11-2017 7:37 PM
Moderator's note:
Post split to its own thread from here and title changed.
Forum Moderator and Customer
23-11-2017 4:45 PM
@trombone Have you tried contacting Madasafish support?
22-01-2018 7:34 PM
Madasafish refers me to plusnet
Madasafish states only provides email
22-01-2018 7:45 PM
23-01-2018 7:16 AM
referring to my original question :-
Unable to access my website www.armadajazz.co.uk for uploading / changing content
FTP worked up to October last year, then for just one day 2 weeks ago, when I successfully uploaded revised content
I'm using Classic FTP by NCH Software, which I've used for several years without problems
extract from Classic FTP Log of Jan 11th :
22:10:11 Connecting to server: www.users.freenetname.co.uk.
22:10:11 Connecting...
22:10:11 Response: 220 ProFTPD Server [freenetname.co.uk]
22:10:11 Command: USER bandstand
22:10:11 Response: 331 Password required for bandstand
22:10:11 Command: PASS ******
22:10:11 Response: 230 User bandstand logged in
22:10:11 Connected OK.
does any of this help in solving the problem?
24-01-2018 2:07 AM
That FTP log shows login has been successful.
I would expect to see a list of the root folder contents at this point - don't you get that? Possibly this would be a folder such as /htdocs which you'd have to enter to find your website files.
25-01-2018 10:37 PM
FTP worked up to October last year, then for just one day 2 weeks ago [Jan 11th], when I successfully uploaded revised content
The extract from Log is of Jan 11th - the only time that I have been able to access my website since October, despite several attempts per day
25-01-2018 11:18 PM - edited 26-01-2018 3:32 PM
So what does the log show now it's failing?
Edit: it's definitely working:
~$ ftp www.users.freenetname.co.uk Connected to www.users.freenetname.co.uk. 220 ProFTPD Server [freenetname.co.uk] Name (www.users.freenetname.co.uk:[redacted]): *******nd 331 Password required for *******nd Password: 230 User *******nd logged in Remote system type is UNIX. Using binary mode to transfer files. ftp> ls 200 PORT command successful 150 Opening ASCII mode data connection for file list drwxrwxr-x 2 ftp ftp 4096 Jun 10 2004 etc drwxrwxr-x 4 ftp ftp 4096 Apr 11 2017 public_html
28-01-2018 8:50 PM
Classic FTP Log this afternoon 2018-01-28
13:05:50 Classic FTP Run
13:05:51 Click the Connect button to connect to a site
13:07:38 Connecting to server: www.users.freenetname.co.uk.
13:07:38 Connecting...
13:07:40 Failed to connect to server www.users.freenetname.co.uk on port 21. Check that you have the correct server address and port.
13:07:40 Unable to log onto server.
13:08:00 Connecting to server: www.users.freenetname.co.uk.
13:08:00 Connecting...
13:08:02 Failed to connect to server www.users.freenetname.co.uk on port 21. Check that you have the correct server address and port.
13:08:02 Unable to log onto server.
28-01-2018 10:57 PM
What IPs do you get if you do an nslookup at a command prompt? My result:
C:\>nslookup www.users.freenetname.co.uk Server: dsldevice.lan Address: fe80::9e97:26ff:fe94:acb8 Non-authoritative answer: Name: www.users.freenetname.co.uk Addresses: 212.159.8.151 212.159.9.151
Does it connect if, rather than using Classic FTP, you try Command line FTP from a Command prompt as demonstrated by Bob. This also connects for me.
C:\>ftp www.users.freenetname.co.uk Connected to www.users.freenetname.co.uk. 220 ProFTPD Server [freenetname.co.uk] 200 UTF8 set to on User (www.users.freenetname.co.uk:(none)):
- Everything else
