FTP from a different router
- Everything else
- FTP from a different router
26-11-2011 12:04 PM
New one on me, any ideas folks?
Thanks.
Re: FTP from a different router
26-11-2011 12:53 PM
26-11-2011 2:15 PM
Quote from: MisterW I believe you can only access webspace using FTP from a PlusNet connection.
There was no mention of this when I spoke with technical support at Madasafish last Thursday.
26-11-2011 2:27 PM
Vigor 130 modem, pfSense 2.6.0 router, DrayTek WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
26-11-2011 2:32 PM
http://www.plus.net/support/hosting/webspace/webspace_details.shtml
26-11-2011 6:37 PM
26-11-2011 8:50 PM
Quote from: Peter Correct. The homepages server is accessible from any internet connection. The cgi server is only accessible from a Plusnet internet connection.
So any ideas how I can resolve the 530 issue Peter? I've tried using FileZilla, Core FTP, and FireFTP and they all give me the same error message. When I use any of these apps to access my own webspace it connects without a problem so it can't be a router issue.
26-11-2011 9:01 PM
Also these instructions seem reasonably clear assuming that there isn't a block on non Madasafish Accounts
http://www.madasafish.com/support/features/my_webspace/ftp_settings/uploading.shtml
26-11-2011 9:08 PM
26-11-2011 9:23 PM
The 'help' says -
Quote The 'High' setting will prevent the use of VPN software, Active FTP sessions and software which lets you to synchronise your computer's time using an external source. If you want to use these applications, switch to the 'Low' setting.
You could also check whether your router is inadvertently port forwarding FTP somewhere, also the firewall on your PC may be doing something silently.
27-11-2011 7:59 AM
Thanks for your thoughts and help with this guys... I guess some days you just can't win
- Everything else
