FTP access to new CGI platform
- Everything else
- Re: FTP access to new CGI platform
21-02-2014 3:12 PM
For dunbarney, which was the first to be migrated,I have to use the userid ccgi.dunbarney.plus.com and the new ftp password that I set up via the FTP Manager in Control Panel to login via Dreamweaver. With this login I can see the directories above public.
For ajreid, for which I just got the migration complete email today, am still able to login in Dreamweaver using my old username (ajreid) and password but am not able to login with the new ccgi.ajreid.plus.com. With my old login I cannot see the directories above public.
Can you explain what is going on?
21-02-2014 3:35 PM
I would also expect you to be able to carry out the same operations on your second ajr… account. That is login to the Control Panel using ccgi.ajr….plus.com (with the temporary password from its email), change that password, login and set its master FTP password. Then use Dreamweaver FTP with the ccgi.ajr….plus.com username and master password to access its files.
I think the reason you can't do this at the moment is that, whilst DNS has switched to Hostopia for your dunxxx… account it hasn't for the ajr… account. The "completed" email looks to be a little premature. Hopefully DNS will switch soon.
David
21-02-2014 3:44 PM
21-02-2014 4:00 PM
Quote from: aenea For ajreid, for which I just got the migration complete email today, am still able to login in Dreamweaver using my old username (ajreid) and password but am not able to login with the new ccgi.ajreid.plus.com. With my old login I cannot see the directories above public.
Sorry about this. Turns out the DNS records weren't changed when we sent the last batch of welcome emails out (~250). This means the ajreid account will still have been pointing at Plusnet. We corrected this a couple of hours ago so all should be well before long.
C:\Windows\System32>nslookup ccgi.ajreid.plus.com
Non-authoritative answer:
Address: 84.92.1.4
Aliases: ccgi.ajreid.plus.com
As soon as that IP changes to 91.136.8.9 you should be good to go.
21-02-2014 11:35 PM
Quote from: Bob As soon as that IP changes to 91.136.8.9 you should be good to go.
The DNS switch has been made now.
C:\>nslookup ccgi.ajreid.plus.com
Address: 91.136.8.9
22-02-2014 6:18 PM
1) Host / IP / URL, which was: cshell.plus.net
2) Username, which was: myusername (ie.e the bit of my email address between the @ and .plus.com)
3) Password, which was: ********* (OK so it wasn't really *****)
What are the equivalent data I need to enter to FTP into the new CGI platform?
Thanks,
stuck
22-02-2014 6:33 PM
STUCK I'm using the FTPManger within https://hosting.plus.net/portal which allows you to upload/edit files on your site in the meamtime
FTP access details to new CGI platform
22-02-2014 6:34 PM
I've logged into FTP Manager and created a user / set password but it does not work.
Re: FTP access details to new CGI platform
22-02-2014 6:45 PM
Then in your FTP client set both username and hostname to your domain name (ie ccgi.myusername.plus.com) with the master password you've just defined. That should give FTP access to all directories.
David
22-02-2014 6:48 PM
Quote from: bridgesystems ...I'm using the FTPManger within https://hosting.plus.net/portal which allows you to upload/edit files on your site in the meamtime
I think you mean File Manager.
The FTP Manager is a different utility that allows you to creates users that can then have FTP access to defined directories. What I want is unlimited FTP access. Within the FTP Manager there is an option to create a master password and I have done that but it hasn't helped me connect using CoreFTP.
stuck
22-02-2014 6:52 PM
http://community.plus.net/forum/index.php/topic,124049.0.html
From the look of it this one was created in error when the OP was trying to reply to my question at reply #5 of that thread.
Thanks,
stuck
22-02-2014 6:53 PM
David
22-02-2014 7:01 PM
Perhaps it's just me but that's the second time I've encountered a considerable lag between setting a password and the system then letting me use it. Last night I was able to use the initial password in the setup email but it wasn't until this morning that I could use it and actually log in. Now I create a master FTP password and it was several hours before it allows FTP access.
stuck
dick:quote
22-02-2014 7:07 PM
22-02-2014 7:09 PM
Quote from: Oldjim threads merged as suggested
Thanks!
- Everything else
