FTP Issue
Strat
Fixes: 565
FTP Issue
There seems to be a problem with FTP to homepages last night and today intermittently, which might need a touch from @bobpullen.
This is the log from my weather app which uploads to my site.
05/10/2018 14:15:31 : FTP Connect Timeout
05/10/2018 14:15:31 : FTP Connect Error, Error code = 426
05/10/2018 14:16:01 : FTP Connect Timeout
05/10/2018 14:16:01 : FTP Connect Error, Error code = 426
05/10/2018 14:16:31 : FTP Connect Timeout
05/10/2018 14:16:31 : FTP Connect Error, Error code = 426
05/10/2018 14:17:01 : FTP Connect Timeout
05/10/2018 15:15:30 : FTP Connect Timeout
05/10/2018 15:15:30 : FTP Connect Error, Error code = 426
05/10/2018 15:30:30 : FTP Connect Timeout
05/10/2018 15:30:30 : FTP Connect Error, Error code = 426
05/10/2018 15:31:00 : FTP Connect Timeout
05/10/2018 15:31:00 : FTP Connect Error, Error code = 426
05/10/2018 15:31:30 : FTP Connect Timeout
05/10/2018 15:31:30 : FTP Connect Error, Error code = 426
Edit: removed 'intermittently' as it's now more like permanent.
16 REPLIES 16
Strat
Fixes: 565
Re: FTP Issue
Seems to have been sorted later this evening...fingers crossed.
Strat
Fixes: 565
Re: FTP Issue
Today it is still failing with an error messages like
'Insecure server, it does not support FTP over TLS' from Filezilla and
'FTP Connect Error, Error code = 426' from my weather app.
But it is intermittent.
Strat
Fixes: 565
Re: FTP Issue
Maybe it's to do with this...
mywebstats.plus.net uses an invalid security certificate. The certificate expired on 04 October 2018, 11:28:00. The current time is 8 October 2018, 17:24.
@bobpullen
Penbwlch
Re: FTP Issue
I am getting the same problem. I use a weather program called Cumulus and am getting FTP errors reported. Does this thread mean that the problem lies with Plusnet?
bobpullen
Fixes: 316
Re: FTP Issue
Cheers for pointing this out, and apologies the thread's gone unanswered until now ☹️
I've raised it with the relevant folk.
Strat
Fixes: 565
Re: FTP Issue
Thanks @bobpullen and I know how busy everyone is.
@Penbwlch it was my Cumulus that first flagged it up to me.
Penbwlch
Re: FTP Issue
If there is any information you need from me, please just ask.
bobpullen
Fixes: 316
Re: FTP Issue
@bobpullen
@Strat, where are you seeing this error?
The mywebstats.plus.net cert has expired and we're looking to get it renewed (ref: IMT-2866). AFAIK though, this should only really affect viewing of your Webstats via the portal:
Do you have raw weblogs enabled I wonder? I think this can be determined by the presence of a 'logs' directory in your FTP root.
Strat
Fixes: 565
Re: FTP Issue
@bobpullen
It was when I tried to view webstats via the portal that I received that error message.
I thought maybe the cert was also involved in access authentication to homepages via ftp.
Wild goose chase I guess Embarrassed
bobpullen
Fixes: 316
Re: FTP Issue
Ah, OK. Well at least that one's going to get fixed. Doesn't bring us any closer to establishing cause of the FTP errors though Undecided
Kelly
Fixes: 9
Re: FTP Issue
I think we know what's causing the errors.  Hopefully a change early next week should resolve.
Kelly Dorset
Ex-Broadband Service Manager
bobpullen
Fixes: 316
Re: FTP Issue
This bit should be fixed now. Shout up if not.
Penny
Fixes: 8
Re: FTP Issue
@bobpullen wrote:
@Strat wrote: Maybe it's to do with this...
Yes, the daily warning (since 5th October) has disappeared, now.  Thanks Bob, appreciated.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Kelly
Fixes: 9
Re: FTP Issue
Hopefully the connection errors should have stopped as well?  (Change made on Monday morning)
Kelly Dorset
