FTP 550 error on upload
- Everything else
- Re: FTP 550 error on upload
15-09-2007 9:10 PM
First: What's happened to the simple web builder wizard tool. I can't find it any where.
Second: I can log into the FTP server and see the files but I cannot upload a modified version. I get a 550 Access is denied error. I appear to have lost the write permission.
Any clues as to what I'm doing wrong would be appreciated.
15-09-2007 9:27 PM
Quote from: silentmonkey First: What's happened to the simple web builder wizard tool. I can't find it any where.
The web builder was removed due to security issues.
Quote from: silentmonkey Second: I can log into the FTP server and see the files but I cannot upload a modified version. I get a 550 Access is denied error. I appear to have lost the write permission.
Upon reading the question again, that error is usually when you don't have write permissions on the server. Are you sure you're uploading to the correct area?
15-09-2007 9:34 PM
The permissions on the file are:
Owner RW
Group R
AllUsers R
The folder is HTDOCS and the permission on the folder is
Owner RWX
Group R X
AllUsers R X
15-09-2007 9:47 PM
1) able to open the original file?
2) delete files?
3) upload alternative files?
It usually means you don't have write permissions on the server but I haven't any experience with the PlusNet webspage, so I'm sure someone more able to help you will be along soon
15-09-2007 10:06 PM
Quote from: MikeWhitehead On your web space, are you:
1) able to open the original file? Yes
2) delete files? No
3) upload alternative files? No
15-09-2007 10:09 PM
I'm not sure why you would be denied access by PlusNet to your webspage, seems a bit odd. Raise a ticket and see what they say. Sorry I couldn't be any more help.
15-09-2007 10:47 PM
Quote from: MikeWhitehead Definately logged in?
I Guess so. I've used the same name and password as I logon to the portal with. And it does list my pages when logged on.
Thanks for you help so far
15-09-2007 10:52 PM
15-09-2007 10:54 PM
16-09-2007 12:14 AM
Raising a ticket is still required though as something has happened to it.
16-09-2007 2:10 AM
Raise a ticket and I'm sure it'll be sorted quickly.
16-09-2007 10:50 AM
One thing I forgot to mention is that I'm on a SBS network which was recently upgraded to ISA2004. There is a default setting buried deep with in the ISA access rule that limits FTP to read only. Removed the tick from the box and all is now well.
Thanks for the quick responses from everyone.
16-09-2007 2:41 PM
- Everything else
