FIBRE On Demand
FIXED- Subscribe to RSS Feed
- Everything else
- FIBRE On Demand
23-11-2017 1:10 PM - edited 23-11-2017 1:12 PM
Hi
I just did an availabilty check for my neighbour using https://www.dslchecker.bt.com
Curuous to check my upload speed - in line with recent posts on Unlimiteed Fibre upload speeds increasing - I found this entry under my phone number: I note it says FTTP on demand is available.
Very surprised to see this .
Does PLUS Net offer Fibre on demand?
How do I order it and what does it cost?
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 13.1 | 7.2 | 1.2 | 0.8 | 5.4 | Available | -- | -- | Yes | -- |
VDSL Range B (Impacted) | 9.5 | 2.8 | 1.2 | 0.5 | 2 | Available | -- | -- | Yes | -- |
Featured Products |
Downstream Range(Mbps) |
WBC FTTP Availability Date |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | -- | -- |
Fixed! Go to the fix.
Re: FIBRE On Demand
23-11-2017 1:40 PM
Re: FIBRE On Demand
23-11-2017 1:55 PM
This would be for a business customer , any idea who can supply it? And cost!
Re: FIBRE On Demand
23-11-2017 1:58 PM - edited 23-11-2017 2:02 PM
FoD shouldn't be confused with FTTP. FoD is essentially a bespoke product offered in FTTC areas and as a result is very expensive and currently subject to 36 month minimum term.
In its current form FoD costs are subject to a £750 installation charge, then there's a distance related charge which are measured radially from the local Fibre aggregation node to your property that starts at £200 (for distances upto 199m) but rises to £ thousands, then the annual rental of £1188. All those prices are ex VAT costs to the ISPs. There's also potentially excess construction charges too
But there are major changes to FoD coming in in Feb
Only a few providers currently offer FoD too atm, such as FluidOne and Cerberus
23-11-2017 2:05 PM
Have a look at this thread on TBB, you'll find links to Cerberus & Fluidone there.
