FAO: Chilly - CGI Backup script
- Everything else
- Re: FAO: Chilly - CGI Backup script
09-08-2007 5:01 PM
Hi Chilly,
Just seen a thread in p.s.customer-feedback from Noel Bell reporting that there are some problems with your CGI backup script.
The threads called Re: Planned SQL/CGI maintenance - 8th August 3:00am-7:00am if you fancy taking a look
Quote When I first saw this I went to do a backup of my cgi site (just in case).
I'm using ChilliPenguin's backup script which has worked well for a couple
of years.
I find it doesn't work now.
The GZ bit seems to work, but the TAR bit doesn't.
It worked last on the 14/06/08.
Anything changed, folks?
Regards,
Noel
Message 1 of 4
(3,541 Views)
3 REPLIES 3
09-08-2007 5:35 PM
The last cron run of my copy of the 05/08/2007 worked, and a command line run a few moments ago worked.
Chilly
Chilly
Message 2 of 4
(974 Views)
10-08-2007 10:39 AM
Can I ask where the script can be accessed/downloaded?
Thks
Thks
Message 3 of 4
(974 Views)
10-08-2007 5:53 PM
Message 4 of 4
(974 Views)
- Everything else
