Extraneous characters in 'advance notice of direct debit' email
- Everything else
- Extraneous characters in 'advance notice of direct...
22-03-2018 5:04 PM
Within the last two months I have been getting the above where the pounds sign is being replaced with a black diamond with a white question mark in it.
I know Yahoo mail have been having problems because of misconfiguring '8bitmime' on their SMTP system.
Is PlusNet having the same problem ? I could find no mention of the character set being use when viewing the message source.
I have UTF8 set for display in Thunderbird which should be able to translate just about anything (apparently).
Anyone else getting this problem ?
Re: Extraneous characters in 'advance notice of direct debit' email
22-03-2018 5:29 PM
I see the same if I view the email in webmail on Chrome, Pale Moon & Edge but the email renders correctly in Outlook 2016.
22-03-2018 11:53 PM
UTF-8 will dispaly characters correctly only if all the octets present are valid UTF-8 ones. This excludes the range A0-FF. The Plusnet £ sign is probably in that range. Does it display correctly if you view the message with Western encoding?
23-03-2018 9:42 AM
Hi David,
Have tried Western (ISO-8859-1) and Western (Windows-1252) but no change.
23-03-2018 1:07 PM
My default outgoing is UTF-8 and incoming Western (iso-8859-1) and works OK for me. Incoming UTF-8 is detected and displayed as such.
Have you tried selecting a message in the list then clicking View->Text Encoding and selecting Western?
23-03-2018 2:48 PM
Thanks spraxyt - changing text encoding to Western worked.
Will follow your suggestion and set incoming as Western (ISO-8859-1) and see how it goes.
23-03-2018 5:10 PM
I don't recall setting those defaults when I installed Thunderbird on this relatively new PC so I assume they are the set-up values. I think it is plain text messages where the default will be used, and Western (ISO-8859-1) is probably appropriate for us. HTML emails might use UTF-8 but they will say so and that is respected.
23-03-2018 11:17 PM
I cannot remember the set-up values on initial installation. I 'played' with text encoding to help a friend who is on Yahoo (using IMAP in Thunderbird). They (Yahoo) have a problem with their SMTP as detailed here: https://forums.yahoo.net/t5/Sending/Yahoo-SMTP-server-advertising-8bit-capability-incorrectly-and/td...
I then made enquiries on another forum I am on because I was getting the same problem with email alerts from them. The administrator changed outgoing encoding to UTF-8 and all was okay. That is why I raised it here.
As stated above I will see how it goes using your set up in post 5.
- Everything else
