Extra IP addresses?
7up
Fixes: 20
Extra IP addresses?
Hi
Is it possible to get extra static IPs from plusnet? If so is it possible to use them with teh Hub2 router or would i need something else to handle them?
I'm mulling over putting a couple of virtual machines online..
3 REPLIES 3
Fixes: 585
Re: Extra IP addresses?
Is it possible to get extra static IPs from plusnet? almost certainly No.
If so is it possible to use them with teh Hub2 router ? No, even if they were available.
Fixes: 251
It has been advised recently that the business has stopped offering fixed IP addresses for sale.  Blocks of (adjacent) addresses were once offered on business accounts ... I am not certain if they were ever available for residential accounts.
As for how multiple WAN IP addresses are managed / configured on a router ... I have no knowledge, but I suspect that needs something more than the basic functionality of a Hub Two.
EDIT: @MisterW has a faster keyboard...
corringham
Seasoned Champion
Fixes: 23
One solution is to use a L2TP tunnel such as offered by AAISP - which I've used for several years. The domestic package costs £10pm and gives one IPv4 and a block of IPv6 addresses with a max speed of 400Mbps and 5TB/m traffic. The business package costs £15+VATpm and increases the max speed to 600MBps and traffic to 10TB/m with a /29 IPv4 block available on request. There is no minimum term.
The advantage over an ISP's static address is that you can keep the same addresses with any ISP or 4G/5G connection - so a fail-over from FTTC to 4G is easy.
