Error: undefined function gregoriantojd()
- Everything else
- Error: undefined function gregoriantojd()
29-09-2007 6:10 PM
Hi There,
I have been using SMF forum for a while and have recently updated it to 1.1.4.
I use a mod called repeating events which modifies the calender function.
I now seem to be getting the above error when I add a repeating event into the calander.
I have got round it for now by deleting the repeating event from the database but I would like to know if this is an issue with the forum mod/update or a problem server side? as reading on the community site for SMF it appears this function is built into php (See quote below)
any help would be appreciated thanks.
Quote Re: Calendar mods Call to undefined function: gregoriantojd() in /h
« Reply #290 on: July 03, 2007, 12:52:42 PM » Quote
I'm in stupid mode today hadn't realised that this is a built in PHP function. So it must be a problem with my host. I checked the PHP ebsite and that lists it as available in PHP4 & PHP5 my host is runninig 4.4.1 so it should work ,shouldn't it?
Message 1 of 3
(3,920 Views)
2 REPLIES 2
Re: Error: undefined function gregoriantojd()
29-09-2007 10:04 PM
According to the PHP calender webpage, PHP has to be compiled with the --enable-calendar switch but PlusNets PHP implementation is not compiled with it according to phpinfo()
So from that I would say it is not available. I have also tried a simple test with several of the functions listed on the page and they all return no function found.
So you can't use your mod on PN.
Message 2 of 3
(713 Views)
30-09-2007 2:40 PM
Thanks for the help, saves me chasing my tail in php scripts which I am having to learn how to edit very quickly with no reference material
I guess I'll have to hope that it might be a feature they will add in future updates of the cgi hosting.. (I won't hold my breathe though).
Cheers again for the heads up.
Regards
Paul.
Regards
Paul.
Message 3 of 3
(713 Views)
- Everything else
