Email and home address visible from check my ip site
- Everything else
- Email and home address visible from check my ip si...
30-04-2025 3:41 PM
I know these “check my ip” sites provide detail of ISP, region, device, browser, ios blah blah. However, a friend tried it with their device (Plusnet is the isp) and saw their email address when they drilled down the isp no.
That can’t be right, can it? Why would Plusnet operate any differently to other isps?
Re: Email and home address visible from check my ip site
30-04-2025 4:24 PM
If they have a static IP , then the reverse DNS for their public IP will show <accountname>.plus.com
30-04-2025 4:40 PM
Second question- even if it was static, would that reverse dnd only be visible to him? Ie no one else? Ie somehow available through posting on social media, forums etc.
Many thanks again
Many thanks?
30-04-2025 5:05 PM
So if they have dynamic (like most), the reverse DNS won’t show?
The reverse DNS for a dynamic IP shows as <ipaddress>.dyn.plus.net
The reverse DNS is available to anyone who knows (or can detect) the public IP address.
If it is due to a static IP rDNS then its possible for your friend to get a it changed to <ip address>.plus.com
30-04-2025 5:24 PM
Moving forward, wouldn’t it be easier just to change device settings to automatic?
Thanks for your time and expertise.
30-04-2025 5:29 PM
Will he need to approach Plusnet to do that?
If he changes it as suggested, will that prevent the email showing via reverse dns etc?
Regards
30-04-2025 5:39 PM
He will need to ask Plusnet to change the rDNS
30-04-2025 8:53 PM
Moderators Note
This topic has been moved from Broadband to Everything Else
- Everything else
