Email after domain moved in for hosting only
- Everything else
- Re: Email after domain moved in for hosting only
28-01-2011 9:17 PM
The reason I ask is that between my mailbox setttings and Thunderbird settings, emails to the three domains found their way into the correct, separate accounts in Thunderbird. Now, all arrives in just one of them.
TIA
28-01-2011 9:35 PM
28-01-2011 11:54 PM
29-01-2011 10:41 AM
You were actually using myplusnetaccount+mailboxname and must have set up redirects on each of the domains to forward to a separate appropriately named mailbox on Plusnet.
If you use different prefixes for the email addresses used for each of the domains you will be OK, just set up the mailbox (with aliases if there are multiple addresses used for a domain) and it will work.
If you use the same prefix across multiple domains (including your username.plus.com domain) you are stuffed! You would have to separate them using rules in your mail client.
30-01-2011 2:12 PM
I have email coming in to
fred@domain1, mary@domain1, whoever@domain1
fred@domain2, mary@domain2, whoever@domain2
and wish to have them all fall into the same Outlook mailbox which is named domain1
I also have email coming in to my myusername.force9.co.uk address with a variety of identifiers before the @ and I wish these to fall into my myusername.force9.co.uk mailbox in Outlook.
Is there an easy way to automate this?
TIA
30-01-2011 6:50 PM
There is no way of setting rules at the Plusnet end to work differently according to the domain - you can only do it on the part before the @. Anything else you will have to do by creating rules in Outlook.
31-01-2011 11:01 AM
All I have to do now is work out how to get Outlook to filter on the @domain(s).
31-01-2011 7:26 PM
However, when I reply to such an email, the 'from' address in my reply is shown as my force9 username address, ie me@username.f9.co.uk, rather than me@domain.
Is there a solution to this?
TIA
31-01-2011 7:40 PM
31-01-2011 8:00 PM
Tools,
Email accounts
View or change existing accounts
Change
Change the "Your Name" and "E-mail address" fields but leave the login name etc. as they are to access the account
01-02-2011 7:54 PM
Thanks I'll give that a try
@jelv
Thanks for all your help and patience! Care to enlighten me on Thunderbird as I'm running that on another machine and accounts.
01-02-2011 8:06 PM
I also like the way I can easily move messages between mailboxes using IMAP. So with the catch all on I can move messages with different email addresses to the appropriate mailbox.
04-02-2011 10:28 AM
This sounds pretty much like the way Thunderbird works with POP3 in that I can filter and move from account to account. Or am I missing something?
04-02-2011 10:39 AM
04-02-2011 11:11 PM
- Everything else
