EPP Code to Transfer Domain Out
MAS46
Hoping someone from support can help.
I have a domain that came across from the old Totalise/Madasafish days, which I would like to transfer out.  It is an me.uk domain and the new provider apparently needs the EPP code.
20 REPLIES 20
Fixes: 395
Re: EPP Code to Transfer Domain Out
You dont need an EPP code for .uk domains. You just request the IPS tag be changed to the new provider.
I've done 2 transfers recently, you request a transfer in with the new provider. Then change the IPS tag to theirs ( they will specify what their TAG is ) and then their systems see the IPS tag has been changed and the transfer completes.
The only difficult part with a Plusnet/Madasfish domain is that you can't change the tag yourself, you have to request the change. However its one things that you can still do via the 'ticket' system I believe , try https://www.plus.net/wizard/?p=wizard&page=22987&wizard_id=38 when your logged in to the member centre. In my case the domains were previously with fasthosts and I was able to use the control panel to change the IPS tag myself.
Hope that helps
MAS46
Thanks, but going through the sign up process with the new provider (online) it is asking for the EPP code and won't proceed any further ::-(
Fixes: 395
Which provider ?
I know you CAN use EPP fro uk transfer https://registrars.nominet.uk/uk-namespace/registration-and-domain-management/registration-systems/e... but didn't think anyone was actually using it.
MAS46
Thank you, but even more challenging is I don't actually have a plus net account to raise a ticket.!!
MAS46
TheEmailShop
Just need domain hosted and a couple of mailboxes
CJT-80
Fixes: 4
@MAS46
This seems to go against their own information on their website
To fully free transfer of.UK domain names to us you need to instruct the current domain’s service provider to release the domain i.e. change the domain’s registrar Tag to "X" (changed to not cause any issues). This change will bring the domain’s management under our system, hence domain is fully transferred and complete management of the domain such as future renewals and any DNS changes can be carried out through our control panel.
This change only is a matter of one click so it shouldn’t take long for the domain to move from one registrar’s management to others.
I'd suggest contacting them first.
Kind Regards,
CJT
Fixes: 395
@MAS46 Often the new providers transfer form has an space for EPP but it should allow transfer without it.
As @CJT-80  says, their own FAQ says its not needed, and I'd be surprised if any (not just PlusNet) provider would provide an EPP code to transfer a uk domain
MAS46
@MisterW @CJT-80  Thank you both. I will follow up with new provider.
I assume to request the IPS tag change at Plusnet requires a ticket to be raised?
Fixes: 395
@MAS46  as i said above, I think its one of the few things that can still be requested via the ticket system
I have a feeling that as soon as the TAG change request is actioned, your domain hosting by Plusnet/Madasfish will stop working. It shouldn't but I suspect it will (hopefully I'll be proved wrong!)
MAS46
As I don't have a plusenet username, I can't raise a ticket!
Fixes: 395
@CJT-80 Hang on, I'll try and nudge someone who's around and should be able to sort it out.
@MatthewWheeler  any chance you could assist please ?
bobpullen
Fixes: 316
Can you raise a ticket under your Madasafish account? - https://portal.madasafish.com/contact/index.shtml
Fixes: 395
Thanks Bob, I wasn't sure what was possible from a Madasafish account and going by a recent thread https://community.plus.net/t5/Everything-else/Old-Madasafish-domain-name-transfer/m-p/1712537 a PM had been requested.
MAS46
@bobpullen the option to raise a ticket just keeps coming back to the contact us page!
