Drupal 7 Clean URLs
- Everything else
- Re: Drupal 7 Clean URLs
Drupal 7 Clean URLs
25-05-2015 4:03 PM
Does anyone know if it's possible to get Drupal 7 "Clean URLs" working on the PlusNet ccgi site?
Message 1 of 6
(1,553 Views)
5 REPLIES 5
25-05-2015 4:28 PM
I haven't installed Drupal but I'd expect clean URLs to work with appropriate .htaccess settings. What failure are you getting?
David
David
David
Message 2 of 6
(596 Views)
25-05-2015 4:43 PM
I'm getting "The clean URL test failed" and "Clean URLs cannot be enabled" when using Drupal 7's built-in Clean URL compatibility test option. The .htaccess is as provided by the D7 installation. I've tried adding Options -MultiViews but that doesn't seem to help. I tried introducing a syntax error and got a 500 internal error so I know the .htaccess file is being processed.
Message 3 of 6
(596 Views)
25-05-2015 5:13 PM
Found it - I needed to uncomment "RewriteBase /" in the .htaccess file. The test passes now, so I'll have a go at enabling it.
Message 4 of 6
(596 Views)
25-05-2015 6:24 PM
Well done.
Based on guidance documentation it seems that is a common requirement.
David
David
David
Message 5 of 6
(596 Views)
26-05-2015 8:11 AM
Yes, I spotted it in the blurb eventually. I'm new to Drupal and not exactly a whizz with Apache (and especially mod_rewrite!) so there's a bit of a learning curve. Interesting stuff though.
Message 6 of 6
(596 Views)
- Everything else
