Dreamweaver upload
- Everything else
- Dreamweaver upload
Dreamweaver upload
16-12-2007 10:02 PM
Thanks,
Bobin.
Re: Dreamweaver upload
16-12-2007 10:16 PM
So just replace the index.html file with your own home page and it should work.
The web server looks for the following as your home page: index.htm, index.html. index.shtml in that order or precedence.
Also if you are uploading to your www webspace, the files must go into the htdocs directory as that is your root or home directory.
17-12-2007 8:01 PM
I have uploaded naming the site index.html... tried naming the site index.htm and uploading as well. But its still just loading it for a second and jumping back to the Plus Net default site.
If you have Dreamweaver, could you check the settings and tell me:
acess type : ftp
ftp host : ftp.plus.net
host directory : /htdocs/
login : (as given)
password : (as given)
everything else not checked
url prefix : http://www.bibin.plus.com/
Could someone please tell me if this is correct for dreamweaver CS3.
Do see check the site, maybe it will help you to understand what is happening; www.bibin.plus.com
Thanks.
17-12-2007 8:22 PM
Take out the line
<meta http-equiv="refresh" content="1;url=http://webspace.plus.net/webspace_plusnet.html">
and it should work as expected
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
18-12-2007 11:57 AM
There is very little coding but it includes the redirect in the head for unknown reasons.
Possibly the original index.htm has been edited rather than replaced.
18-12-2007 9:07 PM
18-12-2007 9:10 PM
