Dose plusnet Do FTTP
tazfan
i had an Openreach guy knock on my door yesterday saying they have layed Fiber to my door so I should be able to update my internet but on the list off IPS  i don't see Plusnet is this something Plusnet can offer or do i need to move IPS in order to make use off this New FTTP Fiber
4 REPLIES 4
Fixes: 1,483
Re: Dose plusnet Do FTTP
Moderators Note
This topic has been moved from ADSL Broadband to Everything Else
Fixes: 1,483
PN don't currently offer FTTP packages and currently have no plans to do so the last we heard.
You would need to change providers.
Fixes: 48
@tazfan
OpenReach are getting better - when I got FTTP I knew immediately as I'd been speaking to the engineers working on the chamber in my neighbours garden. However, it took them over a year to send me notification it was available!!!
I assume it's actually available to order as they've spoken to you but you can check the following. You need to see WBC FTTP in the left hand column. www.broadbandchecker.btwholesale.com/#/ADSL
As mentioned PlusNet don't currently offer a FTTP product and there is no information as to when (or if) they will. So you'll need to move if you want it (contracts not withstanding!!!).
BT and Zen and the main residential ISP's offering FTTP though there are other smaller ISP's and those more business orientated. It's rumoured Sky will be launching next month (apparently they've started training support staff).
tazfan
Shame that Plusnet have no plans to offer a packages for it shows I can buy an plan now with with a few off the listed ips
I might look into it after my contact ends but I do like the plusnet team so hopefully they will offer it as it be good for my it company that I sometimes work at from home
