Domestic Wi-Fi speeds: are they affected in any way by IP connection type, VDSL/ADSL?
Luzern
Fixes: 9
Provided one has a suitably able modem router, does the faster connection over VDSL affect the domestic Wi-Fi connections one may achieve?
Most like this is a silly question, or something just assumed, but never questioned.Undecided
1 REPLY 1
PeeGee
Re: Domestic Wi-Fi speeds: are they affected in any way by IP connection type, VDSL/ADSL?
Simplistically, the speed you get is the speed of the slowest leg of the connection between the endpoints.
However, you may be asking about type of WiFi signal with various modem/routers - most modern devices are dual band and the type of connection is variable/cost related, made confusing by manufacturers giving the "total" available bit rate, eg 900Mb/s = 600Mb/s @ 5MHz + 300Mb/s 2.4GHz - throughput is always lower due to overheads and/or contention.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
