Domains on this account missing
REE
I have three domains registered through Plusnet. However since I no longer use Plusnet as my ISP, I've found that there are no domains listed on the page - https://www.plus.net/my.html?action=domainv2 ie the page is just blank where the list should be.
I spent 40 mins on the phone to the support line but they couldn't find a solution.
I'm not sure what to do next, as I need to amend the DNS records, in preparation for selling them.
Any advice for what I should try next?
Tags (1)
10 REPLIES 10
Fixes: 585
Re: Domains on this account missing
Have you recently left Plusnet or have you had an email only account with the hosted domains for some time ?
rflitcroft
Are these .uk domains?
REE
I left some time ago, so yes, just email since.
REE
Yup, all .co.uk domains
Fixes: 585
Thanks for that confirmation. I'll try escalating this to see if one of the Help team can sort out what's happened.
Are the domains showing on whois as still registered or have they expired ?
rflitcroft
If you get no joy with Plusnet, it is possible to get control of the domains via Nominet by logging into Online Services. They will make a small charge though for a change of registrar.
REE
Hi, that would be great, if you are able to escalate this issue. Thank you.
Just to confirm, the domains are still registered to me.
REE
Thanks for this info. It’s good to know that there is a fallback if I can’t get any joy out of Plusnet.
Marsh
Fixes: 41
Hey @REE
I’m more than happy to look into this for you. I’ve opened a conversation on your account and just need a bit more information from you to proceed. Here is a direct link to that question.
https://www.plus.net/wizard/?p=view_question&id=245408865
Josh
REE
Thank you Marsh. I've responded to your question.
