Domain transfer out
jelv
Fixes: 10
Domain transfer out
Does anyone know how long it takes for a transferred out domain to update on Nominet?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
6 REPLIES 6
Chris
Legend
Fixes: 169
Re: Domain transfer out
Shouldn't take long at all, if it's a full transfer the IPSTAG should update pretty sharpish. Let me go take a look.
spraxyt
Resting Legend
Fixes: 75
@jelv I've a feeling the tag change notification has to be done manually because the button-click API process needs updating. Of course the necessary update might have been done, but ...
David
Chris
Legend
Fixes: 169
I think Spraxyt is right, however doing a whois on your domain now shows the new tag @jelv
jelv
Fixes: 10
I can confirm that has gone through - thanks
Fixes: 395
So just to check in case I need to transfer my domian out in the near future.
What is the recommended procedure for minimising the down time ?
Is it to use the control panel 'Transfer out' button OR raise a ticket to request the transfer out and IPSTAG change
HarryB
Fixes: 256
Probably best to raise a ticket. If you let us know if/when you do we'll make sure that it's being looked in to by the right people.
 Harry Beesley
