Domain transfer from Plusnet - help please.
Fixes: 1,662
Re: Domain transfer from Plusnet - help please.
Thanks for getting back to us @Simtech
I think there may be a little confusion with how domain transfers work.
You'll need to change the nameserver from your new host's side, all we'd do is point the domain to your new registrar.
For us to point it we'll need the IPSTAG. Can you add this to the ticket? We'll then let you know once we've actioned it and when you've updated the nameservers, it can take between 4 to 24 hours for DNS to propagate the changes.
Simtech
Hi
I think there is a major confusion all round.
First of all I was advised incorrectly that i should move my domain away from PN but subsequently I have found out that all i need to do is to move my email to new provider.
So basically all I want to do at present now is to transfer my email to another provider and i thought all you had to do was change the MX record accordingly or i have i got that wrong?
Would it be best to start a new post, than continue with one?
R Yates
Anoush
Aspiring Hero
Fixes: 139
No problem @Simtech feel free to carry on this post.
Yeah in theory that should be possible. We’d still be the registrar for your domain, and you’d host it elsewhere.
We wouldn’t change the MX records ourselves. Only the provider who plans to host the domain can do this.
That’ll depend on if your new host will allow a third party provider to register, as some like to register and host.
For example, I know for Madasafish accounts we manage we have to be the registrar and the host.
Personally if you’re getting another provider to host, I would also ask them to take full control and be the registrar (or find a different provider to be a registrar) because our domain services are legacy and we’d struggle to provide the technical support you may need if something should go wrong. Ultimately you may have a better experience with a provider who specialises in domains. Smiley
Let me know if that doesn’t make sense though or if you’ve got further queries.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Simtech
Okay i think its best now of us to bite the bullet and go for it with the domain transfer.
I have updated the ticket with the IPS tag as requested.
R Yates
Fixes: 1,662
Thanks @Simtech
We've done that now.
We'll leave your domain in our domain control system until you've changed the nameservers over to your new host, so that your domain doesn't stop working during what's likely to be a working day for you. Once you've changed the nameservers let us know so we can update things our side and remove your domain from your account.
Simtech
Hi
The other company has advised us that they have changed the nameservers now.
R Yates
Fixes: 1,662
Hiya, excellent no problem. I've just removed your domain from our domain control system now.
Let us know if there are further issues or anything else you'd need help with. Smiley
Simtech
Thank you for all your help.
R Yates
