Domain to ccgi webspace
- Everything else
- Domain to ccgi webspace
23-01-2008 12:54 PM
I have a domain www.mydomainname.co.uk and I want for when people type this into their browser address bar it takes them to our ccgi space which is located at ccgi.ourusername.force9.co.uk
I'm assuming this is possible, can anyone tell me how? I'm fine with altering DNS records if this is required.
Re: Domain to ccgi webspace
23-01-2008 1:37 PM
You will need to log into your account where you bought the Domaon Name, go to the administration page and look for web forwarding section.
Sometimes you'll get option to Mask your URL by clicking "Frames." Doing this stops your original Domain Name from showing on the task bar.
As you are forwarding to a another server, you must add a forward slash ('/') on the end of the redirect name, i.e ccgi.ourusername.force9.co.uk/
Hope that helps.
23-01-2008 1:44 PM
If your DNS servers are hosted with Plusnet, it's actually fairly easy to configure the CGI servers to be the target. If not, you'll have to use the method outlined above (a Framed Redirect)
Let us know
B.
23-01-2008 1:46 PM
Yes the domain is hosted by Plusnet (or Force9 as it was).
I look forward to the "fairly easy" way..
23-01-2008 1:53 PM
Not sure if that's what I'm after.... the www.mydomainname.co.uk is hosted and registered with plusnet (force9) so I was under the impression that I had to change the dns records to something like this (copied from another thread on here)....
Left field Type Pri Right field
mydomainname.co.uk. a 84.92.1.5 (IP address of CGI server)
www cname ccgi.ourusername.force9.co.uk.
although another thread said the cname line should read...
www cname ccgi.force9.net.
..I'm confused! lol
23-01-2008 2:19 PM
HOWEVER
Once the DNS changes have been done, you need to raise a ticket, putting something like:
"I have set up the DNS records for www.mydomain.co.uk to point to the CCGI server. Please can you configure the CCGI server to match"
Basically, the CGI server needs to 'know' that it should be responding to www.yourdomain.co.uk and this part currently requires manual intervention from Plusnet's part.
B.
23-01-2008 2:32 PM
Hopefully they'll have already performed the manual part because of my earlier ticket.
I'll give it a try.
24-01-2008 12:42 AM
24-01-2008 12:20 PM
The only difference being that www.mydomain.co.uk is registered to a third party ( where I have changed the nameservers to point at plus.net's).
So, I don't have the DNS control in my Plus.net account that others do have.
ta
24-01-2008 12:27 PM
If you simply have your current domain provider "redirecting" to your PlusNet webspace, then you should be able to alter the redirection to point to the CGI server
B.
24-01-2008 12:50 PM
I have just realised that in the Domain names page of my Members Centre , under the Domain Hosting settings section there is an option "other, I wish to specify DNS records for hosts under this domain"
Would I use that, to enable the method you are suggesting?
Or, I have now also noticed a Configure DNS records button at the bottom of that page...
Yours also confused
24-01-2008 1:01 PM
Quote from: ketter Or, I have now also noticed a Configure DNS records button at the bottom of that page...
That's the one you need.
Once you've added the two records as per the instructions earlier in this thread, you need to raise a ticket asking that we change your 'web service' to 'semi-auto'
24-01-2008 1:27 PM
- Everything else
