Domain straight to games server
- Everything else
- Re: Domain straight to games server
01-08-2013 10:02 PM
My son has bought a domain name and wants it to point straight to his games server, I know how to make it work for a normal website but this is a new one for me, I guess to 123.reg settings have to point to the ip as in xx.xx.xx.xx:9257 ? help?
Message 1 of 9
(2,460 Views)
8 REPLIES 8
01-08-2013 10:31 PM
Hello there zpeterk,
Do you know which game it is, and where is the domain DNS is hosted? Plusnet, Just-The-Name, or else where?
Thanks,
Matt
Thanks,
Matt
Message 2 of 9
(875 Views)
02-08-2013 7:15 AM
It is currently with 123.reg, the games vary as do the port numbers, he has the required ports forwarded to the server.
Message 3 of 9
(875 Views)
02-08-2013 8:23 PM
Hey,
Depending on what the game is, and if it supports the record type.
You could create an SRV type DNS record, which forwards to the port.
More information here: https://en.wikipedia.org/wiki/SRV_record
Hope this helps,
Matt
Hope this helps,
Matt
Message 4 of 9
(875 Views)
04-08-2013 9:45 AM
Thanks Mattz0r thats exactly what I require
Cheers
Cheers
Message 5 of 9
(875 Views)
04-08-2013 9:06 PM
You're welcome
Message 6 of 9
(875 Views)
16-08-2013 3:00 PM
I am having a bit of trouble getting the host name part correct, I read it should be of the form _srv._tcp.mc.wickedsnake.co.uk. but it does not work, has any any ideas?
Got it by going through al combinations its _mc_tcp.wickedsnake.co.uk
Message 7 of 9
(875 Views)
17-08-2013 7:04 PM
I thought it was something like this:
They might have included _mc as well, I'm not sure! but if it works, that's the main thing
_minecraft._tcp.mc.wickedsnake.co.uk.
Message 8 of 9
(875 Views)
25-09-2013 12:47 PM
easier way of doing it would be to set an A record and then it would be simply a) domain.co.uk:9876 or b) domain.co.uk and the game auto attempts its default port
Message 9 of 9
(875 Views)
- Everything else
