Domain renewal settings for host only
- Everything else
- Domain renewal settings for host only
22-08-2011 1:38 PM
Hi, I've just transferred in 2 domains on a host only basis. I'm on the teleworker package which allows free hosting for up to three domains as I understand it.
When I come to use the configure form at http://bit.ly/oWGmmx I get to the question at the bottom about making my domain renewal choice. I don't want Plusnet to renew my domain registration for me as I will do it myself with GoDaddy when the time comes.
So how do I handle this part of the form? If I just ignore it will my hosting be terminated after 2 years or what?
Any advice would be much appreciated as I've not found an answer to this using search.
Keith
Keith
Message 1 of 2
(760 Views)
1 REPLY 1
Re: Domain renewal settings for host only
30-08-2011 6:32 AM
Hello Frutigen,
You can ignore this option as it won't be required for a hosting only domain package.
If it is a required field, you can either set this to yes or no, it won't affect your hosting as there is nothing to renew.
I hope this helps,
Regards,
Matthew Scully
I hope this helps,
Regards,
Matthew Scully
Message 2 of 2
(171 Views)
- Everything else
