Domain records
- Everything else
- Re: Domain records
Domain records
09-06-2015 3:15 PM
As we cant register .uk domains here I am trying to register mine via Namesco, but Nominet wont wont release till I prove who I am. Problem I cant remember the original email I used with Plusnet for my .co.uk domain. Trying to get any help from the normal channels with Plusnet net is fruitless, Nominet says could be easier to get Plusnet to change my registered email
Any one on here have any ideas?
Dave
Dave
Message 1 of 3
(1,551 Views)
2 REPLIES 2
Re: Domain records
09-06-2015 3:24 PM
Hi Dave,
Raise a support ticket and ask that we either clarify or change the administrative address for your domain name. Once that's set to something you can access, you should then be able to get login to your Nominet account by following the directions here.
Message 2 of 3
(380 Views)
Re: Domain records
09-06-2015 3:27 PM
Thanks Bob will try that
Message 3 of 3
(380 Views)
