Domain only works with www.
- Everything else
- Domain only works with www.
01-04-2014 5:04 PM
Hi peeps, sorry if i'm asking a silly question by I have a domain registered with plusnet and a static ip address. I have set a DNS A record with left field of www and right field my static ip. I have also set a cname record with my domain again pointing to my ip address. I can access my site only by using www in front of my domain. Any ideas where i'm going wrong.
Message 1 of 3
(957 Views)
2 REPLIES 2
Re: Domain only works with www.
01-04-2014 5:11 PM
You can't point a CNAME to an IP address. You're also missing a qualifying dot from the left-hand side of the domain.tld record.
By not putting a '.' after your domain name, not only have you pointed a CNAME to an IP address but you've also effectively done this:
What you needed was this:
I've corrected the record for you, you'll just need to wait ~24 hours or so for the DNS to propagate.
domain.tld CNAME 84.92.xxx.xxx
domain.tld.domain.tld. CNAME 84.92.xxx.xxx
domain.tld. A 84.92.xxx.xxx
Message 2 of 3
(318 Views)
01-04-2014 5:14 PM
Thanks Bob, that was fast
Message 3 of 3
(318 Views)
- Everything else
