Domain name problems last year - are they fixed yet?
- Everything else
- Domain name problems last year - are they fixed ye...
01-05-2020 4:26 PM
Like several other people I had a problem last year with the non-renewal of my domain name and with the resulting loss of emails over several days. Could someone please tell me whether this has been fixed or whether it will be necessary to post something on this forum in order to get it done? How soon before the renewal date (and I'm not exactly sure when mine is!) would I need to get in touch to avoid having the same problem this year?
Many thanks for taking the time to reply.
Re: Domain name problems last year - are they fixed yet?
04-05-2020 3:31 PM - edited 04-05-2020 3:45 PM
Good luck with that. I've been trying to get an answer to a similar question (https://community.plus.net/t5/Everything-else/Domain-Name-Renewal/td-p/1729034) for two weeks here without a response.
Edit: scrap some of the above - I finally found the 'Renewal' button.
28-09-2020 4:51 PM
Can you tell me where you found the 'renewal button'? I have webmail with madasafish as well as plusnet and the domain is with madasafish.
28-09-2020 10:51 PM
It's not easy or obvious, to be honest. I've just spent 10 minutes trying to find it again.
(I'm assuming that you'll have to login to Member Centre with your Madasafish login details rather than your Plusnet one)
It's at: Member Centre > Manage Account > Domain Names > Manage Your Domains > Configure, then see 'Renewing your domain' at the bottom.
- Everything else
