Domain name over CCGI path - Help
- Everything else
- Domain name over CCGI path - Help
17-11-2008 8:51 AM
Hi everyone,
I am currently trying to get my domain name to display in the address bar when visiting a forum hosted on my ccgi webspace. I have attempted to alter the DNS records after contacting customer services and being pointed to a link. Since doin g this all that has happened is that the site is now displaying an error 404 message. http://www.uni-nut.co.uk this is the address. How should the dns record be set up? i have the original record pointing the domain name to my web space ip address and since then have added a record that reads as below:
Left Field (cant remember the header) Right Field
uni-nut.co.uk. CNAME ccgi.plus.com.
is the above incorrect? if so what should it be?
sorry if this has already been asked somewhere else and i have missed it.
Looking forward to getting some advice on this.
Message 1 of 3
(959 Views)
2 REPLIES 2
Re: Domain name over CCGI path - Help
17-11-2008 6:20 PM
What you have set up is incorrect. Below is what you should have if you want to point www.uni-nut.co.uk to your cgi space.
Left Field Type Right Field
www CNAME ccgi.uni-nut.co.uk.
For a more detailed tutorial about setting up DNS records have a look at http://usertools.plus.net/tutorials/id/14
Message 2 of 3
(147 Views)
28-11-2008 12:30 AM
Hi
I think I've already updated your domain records on the 17th and it worked.
is there anything else that you are trying to do?
Message 3 of 3
(147 Views)
- Everything else
