Does Plusnet support phpBB3 ?
- Everything else
- Re: Does Plusnet support phpBB3 ?
06-10-2007 4:52 PM
Just wondering if Plusnet support the requirements of phpBB3, and if any users have upgraded their forums to this on Plusnet servers yet - what was your experience of doing this - good/bad?
thanks!!!
rob
thanks!!!
rob
Message 1 of 7
(2,337 Views)
6 REPLIES 6
06-10-2007 4:54 PM
Yep, just had a look glance at the phpBB3 requirements list and everything seems good to go
Message 2 of 7
(559 Views)
07-10-2007 9:10 PM
I know that at least one customer has phpbb3 currrently active on the cgi space so it shouldn't be a problem.
Message 3 of 7
(559 Views)
08-10-2007 11:57 AM
I had phpBB3 RC3, 4 & 5 running - forums worked fine but gave up as each one got hijacked and pointed to Turkish site.
Currently running http://www.php-fusion.co.uk/news.php which has survived since 18th Sept.
Message 4 of 7
(559 Views)
09-10-2007 6:12 PM
i just uploaded the phpBB-3.0.RC5.tar.bz2 and attempted to extract it using the 'tar' command, but it says it's not a gzip file - can't now see a gzip version on phpBB.com ?? sure they used to be???
Message 5 of 7
(559 Views)
09-10-2007 6:29 PM
There's a bz2 tar of phpBB RC5, is that any good to you?
http://downloads.sourceforge.net/phpbb/phpBB-3.0.RC5.tar.bz2?download
Message 6 of 7
(559 Views)
09-10-2007 6:50 PM
that's what i used - not sure if these days i need to .zip and do it all manually?? anyone got any experience of this? cheers!!!
Message 7 of 7
(560 Views)
- Everything else
