Do OpenReach dig and lay their own Fibre even if another provider has already done so
- Everything else
- Re: Do OpenReach dig and lay their own Fibre even ...
- « Previous
- Next »
Re: Do OpenReach dig and lay their own Fibre even if another provider has already done so
13-02-2025 4:21 PM - edited 13-02-2025 4:22 PM
You said "small OR pit in our cul-de-sac which only has 5 properties"
This is where OR will install the CBT - a 6 port version. From there a single cable will work backwards to an OR Aggregation Point in another chamber. The fibre cable may (probably won't) not go anywhere near the FTTC cabinet.
Message 31 of 32
(276 Views)
13-02-2025 4:51 PM
ICBW, but I suspect OR don't use 6 port CBTs, so it'll likely be an 8-port.
Message 32 of 32
(264 Views)
- « Previous
- Next »
- Everything else
