Discussing the removal of 'View My Broadband Usage' for customers on un-metered products
Fixes: 1,483
Re: No more usage info for unlimited broadband products
Do you have one or many computers to monitor?
VileReynard
Fixes: 20
It's not just the computers any more...
You can accumulate a reasonable usage just using TV streaming.
I'd suggest maybe 1-2GB per hour?
shutter
Fixes: 65
@dvorak  Just the one ! ...
Fixes: 1,483
You can have a look at Nutty https://babluboy.github.io/nutty/
shutter
Fixes: 65
@dvorak  Thanks for the Nutty !...
( nutty in naval parlance is sweets/chocolate ! ! )
Did not install from you link,... so went to google, and asked for the install for Linux Mint 19.... did the terminal work  and it`s up and running...so will check it from day to day...and see how it goes.
Thanks..
( anything else?  similar ? )
