Discussing the removal of 'View My Broadband Usage' for customers on un-metered products
JonoH
Fixes: 157
Over the coming weeks, Plusnet will be removing the VMBU pages on our member centre for all customers that are not on a metered product, that includes customers on the following packages
  • Plusnet Unlimited
  • Plusnet Unlimited Fibre
  • Plusnet Unlimited Fibre Extra
For customers on legacy metered products, the VMBU pages will remain available.
Here is the place to discuss this change and alternative methods for tracking broadband usage for those who might still be interested in monitoring their usage.
Moderator's note by Dick (Strat): Typo corrected.
 Jono H
 Plusnet Community Manager
34 REPLIES 34
Re: Discussing the removal of 'View My Broadband Usage' for customers on un-metered products
@JonoH  In order to kick this discussion off we need to ask what the known alternative methods are?
Or is that something we provide?
JonoH
Fixes: 157
There are so many options @Anonymous that I wouldn't know where to start, my thoughts were that whilst most people simply won't care, for some customers, this might be frustrating and this would be a nice place to try to help them and recommend programs that we've had experience with.
My Killer Network card in my PC monitors my usage but it's not practical for all because firstly I've had to pay for it and secondly it only monitors the traffic from that one device, not the whole network.
 Jono H
Yes, I see, so ideally you would need something at or in the router to get a true idea of the I/O, and TBH it's something I've never really given consideration to as my router already tells me this, but unless you record it each day you could lose some of the data if there's an unexpected restart.
Fixes: 160
Sometimes sight of usage can be a helpful diagnostic tool. Does this change only reference the user’s ability to view usage, or will Plusnet also cease recording user’s unmetered usage as well?
Fixes: 1,483
The Smarthub that I have got reports data up / down since last restart, not sure if the hub one does too?
@Townman _ My guess is that the recording of it is going as well, maybe @JonoH can confirm this, as it makes no sense to record and not make it available.
JonoH
Fixes: 157
We will still have sight of it as we measure it through a tool called Capacity Based Charging (CBC) we're simply getting rid of VMBU and as such the customer's ability to see their own usage.
 Jono H
Fixes: 1,483
Moderators Note
This topic has been moved from My Account / Billing to Everything Else.
Marksfish
Seasoned Pro
Fixes: 4
Viewing the usage is a big plus for me. When I noticed excessive usage on my connection, I was able to tackle the "offender"  and usage has dropped 20 fold over. Without being able to compare my weekly/ monthly usage I would never have known there was an issue.
corringham
Seasoned Champion
Fixes: 16
My router monitors usage, and there is a big discrepancy between the figure Plusnet report and the (much larger) figure that my router reports, so I'm not sure the Plusnet figures are really much use anyway. I believe usage such as streaming video isn't counted by Plusnet, but as I don't stream video over Plusnet I suspect that not all VPN traffic is counted either as most of my Plusnet usage is for work over a VPN.
Legend
Fixes: 255
For those interested, I use a program called 'BitMeter2'. Not sure if it is still available, or if it works on anything after Windows 7, but I found it much more accurate than VMBU, even before the changes to the facility.
I'll check it out now, and report back.
Fixes: 1,483
I believe for somethings that are within the platform CDN use (IPTV, maybe Youtube / Netflix etc.) they aren't reported in the VMBU figures
Fixes: 1,483
Seems to be a newer (?) multi platform version on github https://github.com/codebox/bitmeteros
Legend
Fixes: 255
Thanks, @dvorak . Must admit I've not looked for a replacement, as what I have works for me.
The help file says it works on anything from W2000, but has not been updated for a while, so whether it covers later OSes I can't say.
