Deleting domain from account
- Everything else
- Deleting domain from account
08-02-2011 11:00 PM
I have 5 domains which all have had their IPS Tags and Nameservers changed to PlusNet's but which are automatically renewed by through 123reg.
One of these domains is rarely used and I have set the option within 123reg's control panel to cancel on renewal date of 27.2.2011.
How do I go about removing this domain from the list within PlusNet as there is no direct option for this?
Should I reset the IPS Tag and Nameservers back to 123reg or raise a ticket?
Forum Moderator and Customer
Message 1 of 3
(782 Views)
2 REPLIES 2
Re: Deleting domain from account
08-02-2011 11:16 PM
No point changing the IPS tag as you will no longer have the domain anyway.
After the domain expires, raise a ticket and ask for the domain to be removed from your account and PlusNets DNS servers.
Message 2 of 3
(168 Views)
09-02-2011 6:38 AM
Thanks Peter.
I'd near-enough guessed that'd be the case - just needed it confirmed.
Message 3 of 3
(168 Views)
- Everything else
