Database migration problem
- Everything else
- Database migration problem
07-03-2014 9:54 PM
Hi all,
I've raised a ticket for this but with hindsight thought it worth asking here.
Only half of my database made it across to the new platform this week, when I have investigated it is because of a latent error in the data, (primary key problem). Entirely my problem and I have a backup from last week that I can recover the valid tables that didn't migrate and then fix the one with problems. However from the data that did make it I can see that entries were added to my diary since my backup but the detail is lost. So does anyone know if it is possible to get hold of the dump from humbug which was presumably used to migrate my database so I can manually recover the missing data from there?
Cheers
Alistair
<who will be more careful validating things he thought he had fixed years ago!>
Cheers
Alistair
Message 1 of 3
(749 Views)
2 REPLIES 2
Re: Database migration problem
07-03-2014 11:03 PM
You should still be able to access your pre-migration SQL database on humbug using http://mysql.plus.net from a PlusNet IP.
Message 2 of 3
(243 Views)
08-03-2014 8:24 AM
Why on earth didn't I think to try that!
Many thanks
Alistair
Many thanks
Alistair
Message 3 of 3
(243 Views)
- Everything else
