Database gone on my phpMyAdmin?
me
Not sure what's happened  here.  When I log into phpMyAdmin my database seems to have gone.  It's still there as my website works but I can't see  it in phpMyAdmin. It was there before as I was populating tales via SQL imports.  Any idea what I may have messed up? I've uninstalling and re-installing phpMyAdmin.  Thanks.
7 REPLIES 7
spraxyt
Aspiring Legend
Fixes: 75
Re: Database gone on my phpMyAdmin?
I doubt this is something you've messed up. I have the same problem and from personal contact I know of two other customers who are also affected. I suspect it might result from something two nights ago when my databases 'disappeared' around 00:30. An application running at that time halted while trying to access the database.
The databases were 'back' when I checked next day, and that application continued from where it was up to when I restarted it.
However it wasn't until this afternoon that I checked phpMyAdmin and discovered the access problem.
David
David
DavidEvans
My database has "gone" too, both from PHPMyAdmin and from Website.
How long should I wait before making a fuss, and to whom?
Another David
spraxyt
Aspiring Legend
Fixes: 75
As I have done, I suggest raising a support ticket under Plusnet Hosting (CGI) https://www.plus.net/wizard/?p=wizard&page=23097&wizard_id=38 reporting the problem. Despite the system mentioning 39 hours average response time I hope these will be picked up on Monday.
David
David
reavells
I also have this issue and have also raised a support ticket (have seen various other odd issues occur since Friday.... PHP mail() function stopped working for a while.... various random files had permissions changed from 644 to 000).
If you know the DB name and 1 table name in it then you can try this in phpMyAdmin:
1) Click the "SQL" tab.
2) Execute a query like "select * from <db_name>.<table_name>"
3) Click the "Show All" link on the paging row
4) The DB name then appears along the top of the page next to the server name, and clicking on it shows you all the tables.
Might be useful in the meantime until the issue is properly addressed.
bobpullen
Fixes: 306
I've raised everyone's issues with Hostopia, I'll report back once I've received a response...
bobpullen
Fixes: 306
I've received word that the phpMyAdmin issues should be resolved. You may need to delete your phpMyAdmin install directory from /private and reinstall the application.
@me@butterflies, I've done this with your account and I'm now able to see database content when logged in. I've used your default Plusnet username and your Hosting Control Panel password if you want to give it a go?
spraxyt
Aspiring Legend
Fixes: 75
phpMyAdmin access to my database tables works again now. Initially, whilst the tables were listed some of them showed as corrupted and 'select' access was refused. The relevant applications also showed errors. Using Cntrl-F5 made no difference.
However after a few minutes applications started working again and both phpMyAdmin and Adminer showed no errors. Smiley
David
