DNS setting to new host
Mattrevs
I have created a server with a static IP and my .co.uk domain is currently hosted by plusnet.
Could some one state what the settings need to be in the DNS as there is no real example.
I was thinking this
left field                 type                       Pri                           Right field
www.abc.co.uk      A                                                           123.123.123.101
I don't want it to handle any of my email just host the webite.
Thanks Matt
1 REPLY 1
spraxyt
Aspiring Legend
Fixes: 75
Re: DNS setting to new host
Have you changed the Domain Hosting setting to "Other" so you can add your own DNS settings?
With that changed I think you need the following DNS settings
Left field          Type          Right field
abc.co.uk.          A             123.123.123.101
www                 CNAME         abc.co.uk.
Note that you need full stops after the fully qualified domain names in the left and right fields but *not* after the www,
This will mean that HTTP requests to both abc.co.uk and www.abc.co.uk are directed to your static IP.
David
