DNS Limitations
- Everything else
- Re: DNS Limitations
DNS Limitations
18-11-2016 6:15 PM
I'm trying to use Office365 and I need a number of DNS settings that the portal does not support. This includes:
- CNAME records with an underscore (_) in the right field. This is required to enable DKIM and should be supported.
- TXT records - no option to create these and needed for SPF
- SRV records - no option to create these and needed for Lync functionality
Will the support team (if it's actually possible to get a message to them that is!) be able to create these?
Re: DNS Limitations
18-11-2016 10:21 PM
As far as I'm aware the Plusnet DNS does not support TXT or SRV records so the support team wouldn't be able to create them.
Re: DNS Limitations
19-11-2016 1:27 PM
Move your domain to freedns which supports everything - http://freedns.afraid.org
The only snag is that unless you become a paid subscriber,your domain then becomes shared so that anyone can grab themselves a subdomain from it.
Re: DNS Limitations
20-11-2016 10:36 PM
As an alternative to freedns, have a look at CloudFlare. They primarily do CDN stuff but as part of that will host DNS for free. If you want a paid for option then can recommend DNSMadeEasy ($30 per year) or Azure/Amazon's DNS service ($15ish per year).
No affiliation with any of those companies apart from being satisfied customer (and we have Office365 configurations set up on all 3)
As a side note, you only need those SRV records for Lync functionality if you plan to enable federation (communication with Lync users on other domains)
