DNS A record help
- Everything else
- DNS A record help
DNS A record help
17-04-2012 3:47 PM
I have a friend who's static HTML website is currently hosted on PlusNet.
He wants a new website written in Wordpress, and his current PN hosting cannot support it - I have unlimited webspace/add-ons with Dataflame and I wish to use this for his domain.
I've set up the add-on at the dataflame end, and changed the A record at his end, but nothing appears to have changed.
I'm tried using the A record settings as :
home A <ip address of my Dataflame host>
and
<domain name> A <ip address of my Dataflame host>
Am I doing something wrong? I've used add-ons before on my DF account without any problems.
TIA
Adam
and
TIA
Adam
Message 1 of 5
(1,673 Views)
4 REPLIES 4
Re: DNS A record help
17-04-2012 3:58 PM
It just sounds like the A record might be wrong.
As DNS records are set up on a domain by domain basis you don't need to specify the domain name itself in the left filed (which is what it looks like you've done) instead you'd need to specify a prefix for the redirect such as www (no dots needed on our system).
Here's a page that explains it quite well: http://usertools.plus.net/tutorials/id/14
Let me know if you still need help after that as I can have a look for you.
Adam
Adam
Message 2 of 5
(536 Views)
17-04-2012 4:08 PM
you need it to be
<blank> A <IP address>
Message 3 of 5
(536 Views)
19-04-2012 4:43 PM
Thanks for the responses - putting 'www' in the left field works for me. I hadn't fully understood what the field meant.
Adam
Adam
Message 4 of 5
(536 Views)
19-04-2012 4:56 PM
Message 5 of 5
(536 Views)
