Cuteftp not allowing view of my websitee
- Everything else
- Cuteftp not allowing view of my websitee
08-06-2011 2:13 PM
Why can I not get into my website ?
Each time I enter my website url (www.music2myears.plus.com) I cannot get into it.
Is this a recoverable fault on my part or some strange temporary problem?
Message 1 of 3
(52,951 Views)
2 REPLIES 2
Re: Cuteftp not allowing view of my websitee
08-06-2011 2:41 PM
It looks like it might be the permissions on the HTDOCS folder. I can try to fix it if you'd like?
Message 2 of 3
(422 Views)
09-06-2011 7:11 AM
Quote from: Chris It looks like it might be the permissions on the HTDOCS folder. I can try to fix it if you'd like?
Yes please !
Message 3 of 3
(422 Views)
- Everything else
