Customer CGI/MySQL outage - Tuesday 22nd November
- Everything else
- Customer CGI/MySQL outage - Tuesday 22nd November
Re: Customer CGI/MySQL outage - Tuesday 22nd November
25-11-2011 10:50 AM
Gabe
25-11-2011 11:02 AM
David
25-11-2011 11:15 AM
Is there still a default-encoding error on the login? I'm having to force utf-8.
edit: nope, looks like it was the associated refresh. Login still looking flakey - seems to keep dropping the session and booting me out. Unless I'm missing the obvious, which would be typical for a Friday.
Gabe
25-11-2011 1:17 PM
25-11-2011 1:27 PM
All of our testing and from the other posters in this thread is showing that it's working in the vast majority of cases, yours is the only one that isn't logging in.
Unfortunately due to security reasons I can't test your MySQL login without resetting the password, obviously I don't want to do this as then anything on your CGI space that's using the old password will need updating.
What errors are you getting when logging in and is this via mysql.plus.net ?
25-11-2011 1:32 PM
"Error Cannot log in to the MySQL server" when the language setting comes up as "English" - list doesn't include any with "utf-8", and sometimes
"Error No activity within 1800 seconds; please log in again" when the language setting changes to "English (utf-8)".
Access to MySQL via PHP code works.
The symptoms of the login errors seem like two servers working with two independent sessions.
David
25-11-2011 1:35 PM
25-11-2011 1:48 PM
25-11-2011 2:03 PM
It thinks about it for 5 seconds or so and drops me back at the same login page with some funny characters in the username.
Edit: If I keep trying from the same login screen, every couple of goes I get Error Cannot log in to the MySQL server
25-11-2011 4:49 PM
I did manage to get logged in once after a reboot, but after logging out I've not managed to log in again.
25-11-2011 4:54 PM
25-11-2011 5:20 PM
Shouldn't the problem be mentioned in a service status post?
David
25-11-2011 5:31 PM
We'll take a look at getting a service status out though.
25-11-2011 6:01 PM
There is a difference now in that it is not reporting "Cannot log in to the MySQL server". It just returns to the login screen with the username jumbled.
25-11-2011 6:18 PM
Can log in using FireFox no problem. Can't log in using IE, tried clearing the cach and restarting.
If you look at the html source for the login page the value of 'Username' contains invalid characters, probably because of the character set encoding mentioned in an earlier post.
For no obvious reason I tried <Ctrl> F5 and that caused it to log in but the display didn't have the usual left-hand menu and it threw me off again shortly after.
Update. It didn't work with firefox for more than 30 seconds.
- Everything else
