Curl Error (6) when trying to install a game
BugPilot
I have played the flight simulator game Digital Combat Simulator (DCS) for many years with no issues.  I have done many clean installs, upgrades etc without issue.
This week I wiped the PC and when trying to install DCS I keep getting the subject error, midway through the download.
I have tried setting DNS to Plusnet DNS servers, to google DNS servers, and to CloudFlare DNS servers.
I have wiped the computer, disabled windows defender Firewall and protection and tried to install DCS with just the bare bones Windows 11 installed.
I have also tried adding both www.digitalcombatsimulator.com and cdn.digitalcombatsimulator.com IP addresses to my Windows Hosts file. Same result.
I found that by using a VPN I can download and install the game.  So that is a fix.  But I would rather not have to pay £20 something per year just to be able to install and update this game.
The wider DCS community doesn't have the same problem.
I have been with Plusnet the entire time I have been using this game (20+ years with Plusnet) and never had the issue before.  But what has changed now is that I recently had FTTP installed, which is making me think it may have something to do with this issue.
20 REPLIES 20
Fixes: 382
Re: Curl Error (6) when trying to install a game
@BugPilot Without seeing at which point the system couldn't resolve host name (using three different routes) it is difficult to answer this, but which VPN did you use, as the unnamed host is obviously resolvable?
BugPilot
Hi, I used PIA  VPN(Private Internet Access)
thanks
Fixes: 382
Thanks. As I said, there must be a host somewhere along the route which is a little 'obscure if even Google and Cloudflare can't resolve the hostname. Where is the game hosted/based?
BugPilot
Does this give you that information?
93.115.211.146 | IP Report | DNSlytics
The downloads will start, but will stop at variable times, with the Curl error (6) message
Fixes: 382
So, they are based in Switzerland - thanks. Once I've got my dinner cooking, I'll see if I can get to that address. MY route will be different to yours, as I am not with Plusnet, though.
BugPilot
Fixes: 382
I can get to that address -see below:
1. fritz.box                         0.0%    31    1.5   5.8   1.2 114.3  20.2
 2. lo0-0.bng4.wh-man.zen.net.uk      0.0%    31    7.5  11.1   6.4  63.5  10.1
 3. lag-8.p2.wh-man.zen.net.uk        3.2%    31   12.1  12.3  11.1  13.1   0.5
 4. 51-148-244-49.dsl.zen.co.uk      20.0%    30   11.9  12.4  11.7  13.7   0.5
 5. r2lon2.core.init7.net             0.0%    30   32.8  16.4  12.4  35.4   6.4
 6. r2fra3.core.init7.net             0.0%    30   25.8  24.8  24.1  28.0   0.8
 7. r1fra3.core.init7.net             0.0%    30   29.8  29.4  23.9  53.6   7.7
 8. r1fra2.core.init7.net             0.0%    30   46.4  29.2  23.8  53.5   8.4
 9. r2fra2.core.init7.net             0.0%    30   24.7  25.7  24.0  37.8   3.0
10. 5-180-134-46.init7.net            0.0%    30   29.9  29.8  29.0  31.5   0.6
11. r2zrh2.core.init7.net             0.0%    30   30.0  30.1  28.8  33.7   1.0
12. r1glb1.core.init7.net             0.0%    30   47.2  34.3  28.9 121.2  17.1
13. r1zrh6.core.init7.net             0.0%    30   30.2  34.5  29.0 163.3  24.4
14. gw-nine.init7.net                 0.0%    30   38.5  45.6  28.6 136.3  19.6
15. 178.209.63.118                    0.0%    30   28.6  31.2  28.5  64.9   7.2
16. 109-106-19-246.static.xelon.ch    0.0%    30   64.1  48.3  33.6 120.4  18.1
17. 109-106-19-250.static.xelon.ch    0.0%    30   36.3  39.3  29.5 155.0  22.3
18. www.digitalcombatsimulator.com    0.0%    30   29.7  30.1  28.6  47.3   3.3
BugPilot
Hi John, ok thanks.  But I have to open my game and click on update, the game handles the connection.
Bill
Fixes: 382
I appreciate that, @BugPilot  - but it has to get to the same place. Ideally you need someone on PN to run a traceroute, as it will be totally different to mine - at least until the last few hops.
BugPilot
ok thanks
Bill
Fixes: 382
Just a thought Bill. You could do, or attempt to do the traceroute - at least that way we should be able to see where it hangs.
BugPilot
Good idea, it did hang!
C:\Windows\System32>tracert www.digitalcombatsimulator.com
Tracing route to digitalcombatsimulator.com [93.115.211.146]
over a maximum of 30 hops:
1 3 ms 3 ms 6 ms 192.168.1.1
2 10 ms 9 ms 8 ms 254.core.plus.net [195.166.130.254]
3 12 ms 11 ms 10 ms 84.93.253.119
4 14 ms 9 ms 10 ms 195.99.125.138
5 14 ms 11 ms 11 ms peer2-et3-0-2.slough.ukcore.bt.net [62.172.103.216]
6 * * * Request timed out.
7 * * * Request timed out.
8 22 ms 23 ms 22 ms r2fra3.core.init7.net [5.180.134.19]
9 35 ms * * r1fra3.core.init7.net [5.180.135.128]
10 * 25 ms 23 ms r1fra2.core.init7.net [5.180.135.130]
11 * 24 ms * r2fra2.core.init7.net [5.180.135.127]
12 * 29 ms * 5-180-134-46.init7.net [5.180.134.46]
13 * * * Request timed out.
14 29 ms 28 ms 27 ms r1glb1.core.init7.net [5.180.135.161]
15 31 ms 27 ms 27 ms r1zrh6.core.init7.net [82.197.168.222]
16 36 ms 28 ms 27 ms gw-nine.init7.net [77.109.135.6]
17 30 ms 29 ms 27 ms 178.209.63.118
18 59 ms 54 ms 48 ms 109-106-19-246.static.xelon.ch [109.106.19.246]
19 45 ms 32 ms 31 ms 109-106-19-250.static.xelon.ch [109.106.19.250]
20 33 ms 32 ms 34 ms www.digitalcombatsimulator.com [93.115.211.146]
Trace complete.
Bill
Fixes: 382
It did hit a couple of hops where the receiving server didn't respond to pings (as can happen) - but got there. I wonder if the game serve/update server is elsewhere though, if it gives the response in your screenshot?
BugPilot
Yes I just tried another
1 5 ms 7 ms 5 ms 192.168.1.1
2 9 ms 11 ms 8 ms 251.core.plus.net [195.166.130.251]
3 10 ms 9 ms 11 ms 84.93.253.91
4 10 ms 10 ms 9 ms core1-BE1.colindale.ukcore.bt.net [195.99.125.132]
5 10 ms 11 ms 10 ms peer2-et3-0-1.slough.ukcore.bt.net [62.172.103.214]
8 26 ms 23 ms 24 ms r2fra3.core.init7.net [5.180.134.19]
9 24 ms 23 ms 62 ms r1fra3.core.init7.net [5.180.135.128]
10 25 ms 24 ms 23 ms r1fra2.core.init7.net [5.180.135.130]
11 25 ms 23 ms * r2fra2.core.init7.net [5.180.135.127]
12 27 ms 30 ms 27 ms 5-180-134-46.init7.net [5.180.134.46]
14 28 ms 28 ms 41 ms r1glb1.core.init7.net [5.180.135.161]
15 28 ms 28 ms 29 ms r1zrh6.core.init7.net [82.197.168.222]
16 27 ms 28 ms 30 ms gw-nine.init7.net [77.109.135.6]
17 30 ms 27 ms 29 ms 178.209.63.118
18 175 ms 53 ms 52 ms 109-106-19-246.static.xelon.ch [109.106.19.246]
19 45 ms 175 ms 37 ms 109-106-19-250.static.xelon.ch [109.106.19.250]
20 31 ms 30 ms 32 ms www.digitalcombatsimulator.com [93.115.211.146]
Trace complete.
Not sure what you mean by " if it gives the response in your screenshot?"
