'Could not connect to database'
- Everything else
- 'Could not connect to database'
Re: 'Could not connect to database'
13-09-2007 6:19 PM
14-09-2007 10:07 AM
Needed to load the page once.
This is better to previous, where it needed to be re-loaded several times.
14-09-2007 10:26 AM
'We are currently investigating an intermittent problem with the SQL servers as part of an internal Problem (ID 46165) and hope to have this matter resolved shortly.'
Watch this space
14-09-2007 10:20 PM
Connect DB Error: Can't connect to MySQL server on 'rumpus' (4) Cause #2
Why do I get the feeling that Plus net is run by a couple of geeks from a shed at the bottom of the garden
Cheers
Alistair
14-09-2007 10:59 PM
Database Error
The current username, password or host was not accepted when the connection to the database was attempted to be established!
Again.
Re-loading had no effect so far (5 times re-loaded page!!!).
This concerns the cms with a high number of database-requests per page.
The second cms I use works, though it has only a couple of pages so far.
This problem was never there before until ca. 10 to 14 days ago. So somebody at PlusNet has fiddled around on the MySQL-server(s), and then all the problems appeared......
16-09-2007 12:30 PM
Database Error
Any timescale until when this will be repaired?
17-09-2007 10:34 AM
Quote from: ffupi Anyone else having this problem, or is it only us few?
Yes it's happening on my CMS site running Joomla1.0.12 occasionally.
Getting timeouts after Joomla tries to access database info, also javascript editor times out too.
17-09-2007 6:20 PM
Quote from: flabbio I raised a ticket and the reply was...
Watch this space
Quite handy that response, isn't it! At least they're consistent with their responses
Should we open tickets again or sit tight? It is intermittent but it is very annoying - especially if you create a post and then click save only to find out that there's been a database error!
17-09-2007 8:23 PM
anywhere on the PN portal?
17-09-2007 8:28 PM
19-09-2007 8:52 AM
Quote Unable to establish connection to MySQL
2002 : Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Getting timed out a lot - time for some high tech WD40 to be injected into the system.
On rumpus
19-09-2007 10:18 AM
Warning: mysql_connect(): Can't connect to MySQL server on 'rumpus.force9.net' (4)
The error is preceded by a long pause, so it seems like something is timing out somewhere. Usually pressing Refresh clears it.
19-09-2007 1:06 PM
19-09-2007 1:55 PM
19-09-2007 4:20 PM
Current status is:
1) It remains unacknowledged by PlusNet.
2) No votes so far to help raise it's priority.
Voting in PUGIT does help raise the problem profile within PlusNet.
Get on over there and make your vote count?
MauriceC
- Everything else
