Cooliris and the crossdomain file
- Everything else
- Cooliris and the crossdomain file
14-04-2010 5:39 PM
I'm trying to get the Cooliris Flash app to display photos hosted on my site following the instructions here: http://www.cooliris.com/developer/documentation/?p=embed
I can get the app to display the default stream from Flickr just fine but when I try to have it display an RSS feed of my own, it refuses & says that I need to put a crossdomain.xml file in the root of my web site.
Well, I have put the crossdomain.xml file in the root (http://www.emcorp.force9.co.uk/crossdomain.xml) but it still won't fly.
Should the crossdomain file just work (ie is this actually a Cooliris problem), or do I have to get PlusNet to change a setting on my account to enable crossdomain?
[Moderator's note by Thomas (Be3G): thread moved to a more appropriate board.]
Message 1 of 6
(1,925 Views)
5 REPLIES 5
Re: Cooliris and the crossdomain file
21-04-2010 10:01 AM
I'll assume that's a Communitywide shrug of the shoulders then
Is there no-one from Plusnet on the forum who knows if the crossdomain.xml file should work on a Force9 web site?
Message 2 of 6
(480 Views)
21-04-2010 4:01 PM
If you've used the crossdomain.xml file given at http://www.cooliris.com/developer/reference/media-rss/ it should just work.
Gabe
Gabe
Message 3 of 6
(479 Views)
22-04-2010 8:16 AM
OK thanks Gabe, that eliminates that then. I have used the crossdomain file exactly as supplied.
I'll tinker a bit longer but I think this must be a problem with Cooliris itself. Web searches indicate plenty of other people are having similar trouble.
Message 4 of 6
(479 Views)
22-04-2010 8:35 AM
Just as a quick test, you could try a mymedia.xml file like:
and use the cooliris builder at http://www.cooliris.com/yoursite/express/builder/ clicking on Media RSS and pasting http://ccgi.username.force9.co.uk/folder/mymedia.xml into the Feed URL box. The select grab embed code at stage 3 and paste the code into a .html document. It seems to work.
Gabe
Edit: typo
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/"
xmlns:atom="http://www.w3.org/2005/Atom">
<channel>
<item>
<title>My Image</title>
<media:description> It works.</media:description>
<link>image.jpg</link>
<media:thumbnail url="http://www.username.force9.co.uk/folder/image.jpg"/>
<media:content url="http://www.username.force9.co.uk/folder/image.jpg"/>
</item>
</channel>
</rss>
Gabe
Edit: typo
Message 5 of 6
(480 Views)
22-04-2010 8:56 AM
Very useful pointers, thanks again Gabe.
You know what? I just got it working... typical cos I've been fiddling with it for a couple of weeks, on and off. Turned out to be a single coding error in the embedding HTML. My fault, but the error message about the crossdomain file was a complete red herring. Anyhow, I apologise to Cooliris for suggesting it was their fault!
Thanks for taking an interest. Much appreciated!
Message 6 of 6
(480 Views)
- Everything else
