Connection capping @ 67.997 Mb/s - is this an unofficial limit agreed with BT?
Demonix
Re: Connection capping @ 67.997 Mb/s - is this an unofficial limit agreed with BT?
Sammy,
Cheers for the test results, I can pull the same figures off my kit 😉😀
DLM just appears to have settled at the "magic figure" - which as long as it stays stable is ok, not fabulous but acceptable.
When conditions are optimal it may recalc and rise but won't hold my breath as it is a poor automated management system, ever eager to drop bands but not as swift to raise if conditions/stability improve.
BT line speed estimates overly conservative, plus line length to current cab is under half stated figure.
66mbs is ok though as friends in surrounding villages are lucky to get 3mbs on ADSL or 45mbs on Fttc.
Fttp across UK with implementation of required cabling/ network improvement between now 2025 and 2033 for a properly fast connection is an awfully long wait.
Shame BT is more interested in TV sports rights than investment in a crumbling infrastructure, being part of the same group doesn't help Plusnet.
Best regards
Demonix
RealAleMadrid
Aspiring Hero
Fixes: 59
@Demonix   I am always suspicious when I see sync speeds like 67.997 Mb/s that are very close to an exact whole number, but it isn't a devious BT conspiracy theory, it shows that the line has been banded by DLM setting a fixed speed, it appears @SammyM has missed this important information from the GEA test.
Profile Name - 0.128M-67M Downstream  ( it should be 0.128M-80M )
The test also shows that at some point the maximum sync speed of 79.9 Mb/s has been achieved which it will probably sync at if the banding is removed. Why it has happened is unclear, line drops or interference can cause DLM to band a line. I would suggest that PlusNet should request a DLM reset and in future look more closely at the GEA test results.Roll_eyes
MasterOfReality
Fixes: 57
Hi @Demonix
Here is a fresh GEA test result;
Test OutcomePass
Test Outcome CodeGTC_FTTC_SERVICE_0000
DescriptionGEA service test completed and no fault found .
Main Fault LocationOK
Sync StatusIn Sync
Downstream Speed79.9 Mbps
Upstream Speed20.0 Mbps
Appointment RequiredN
Fault Report AdvisedN
NTE Power StatusPowerOn
Voice Line Test ResultPass
Bridge TapNot Detected
Radio Frequency IngressNot Detected
Repetitive Electrical Impulse NoiseNot Detected
Cross TalkNot Detected
Estimated Line Length In Metres291.3
Upstream Rate AssessmentVery Good
Downstream Rate AssessmentVery Good
Interference PatternNot Detected
Service ImpactNo Impact Observed
Home Wiring ProblemNot Detected
Downstream Policing Discard Rate0.0
Customer Traffic LevelUpstream and Downstream Traffic Detected
TechnologyVDSL
Profile Name0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Sync speed and Profile name are back up where they should be.
Hope this helps
Demonix
That test is great but not my connection!
If you can raise a DLM - remote reset by BTW that would be appreciated! (And yes they can do this without an engineer visit !)
Best regards
Nick
MasterOfReality
Fixes: 57
Hi @Demonix
I'm SO sorry - that was not your BBEU results, you are correct. .
I've sent the request off to get the FTTC DLM Reset actioned
As an aside - you line is within its estimates, therefore our supplier may not progress this forward, however, we will know more in roughly 48 working hours.
Demonix
Alistair,
Thanks for that!
If DLM wasn't such a shoddy mechanism wouldn't have to ask but it is so appreciate the request! And as they can perform the action remotely it's not exactly a big ask, unless it ends up with one of the many BTW engineers who aren't as technically adept as they should be and can't perform the required task or the old system was busy or down excuse - then a reset will actioned at a later date by one of the few proactive and skilled BT engineers ( they do exist but it can take a while to obtain their assistance!)
Jubby
All Star
Fixes: 31
Hi @Demonix
I have now escalated this for DLM reset, due to it being the weekend it may not be processed until 13/08/2018.
You will need to power your router off and back on for it to take effect or you will notice the service drop and reconnect when it has taken effect.
Thank you.
 Lewis G
 Infrastructure Operations Professional
Demonix
No drama Lewis, appreciate the request escalation!
My router will mail me if there are any connection drops but will keep an eye out for BT doing their thing!
Demonix
Noise and crc errors showing on the BT end of my connection , your supplier needs to address issues with their own kit as that would appear to be the reason DLM is banding my BB connection, lines stats show noise / CRC errors on the BTW side (joys of cross talk / line noise on copper as usual ), Can't see that DLM reset has been performed yet as no connection drop or contact from BT - can you chase them up please?
EmilyD
Fixes: 117
Hi @Demonix,
Thank you for getting back in touch. I've tested your line today and can confirm that the DLM reset has been performed and that your line profile is now 0.128M - 80M. The test isn't picking up any issues at the moment:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 66.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 557.5
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Retransmission High - 0.128M-20M Upstream, Retransmission Low
Time Stamp 2018-08-01T12:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 66.9 Mbps 79.9 Mbps 69.7 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 834.0 Sec 900.0 Sec 899.4 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-08-14T11:20:01Z 2018-08-14T11:35:01Z
Ingress Code Violation 1 1
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
The speed estimate for your line is 49 - 71.3mbps so the current sync speed of 66.9mbps is in line with the estimates.
 Emily D
Demonix
Thanks for confirming DLM reset, interesting no connection drop and no change in speed, still noise and errors on BT end but not having a drastic effect apart from mild loss of performance.
adamwalker
Fixes: 221
Hi there, we're seeing a drop at 14:46 yesterday which I'd assume was the DLM reset taking effect. I've just tried to test the line re the noise but the test failed showing that a call is in progress. Let us know when the line is free and we'll check that again.
 Adam Walker
Demonix
Adam, suspect BT didn't actually action dlm reset until today. As of this afternoon circa 16:00 am now seeing 78.661mbs so all good until next time noise occurs on the cab end of my connection or supplier makes a change and DLM kicks in.
adamwalker
Fixes: 221
Make sure you let us know if there's an issue with noise again but hopefully not.
 Adam Walker
Demonix
Thanks Adam, will do!
Line still operating above estimate @ 79.2mbs down and 19.99 up - some errors / noise on BT end but below threshold that would activate DLM so far, fingers crossed it will remain that way.
