Connect to database via PHP
- Everything else
- Connect to database via PHP
10-02-2009 5:05 PM
Hi All, Please can anyone help, i am new to MYSQL, I have set up the database and created a table through PHPADMIN
I then created a small PHP script and put it on the CCGI site and ran it
<?php
$db_host='rumpus.force9.net';
$username='dadio';
$password='********';
$db_name='dadio_f9';
echo "<HTML><BODY>";
$conn = mysql_connect($db_host,$username,$password);
echo "</HTML></BODY>";
unfortunately i keep getting the following error
Warning: mysql_connect(): Access denied for user 'dadio'@'212.159.7.156' (using password: YES) in /share/storage/02/da/dadio/testmatch.php on line 10
I have set the permissions to 755 for the php file, am i missing something obvious .... Please help
<?php
$username='dadio';
Message 1 of 3
(932 Views)
2 REPLIES 2
Re: Connect to database via PHP
11-02-2009 1:27 PM
That message normally means that the password in your script is incorrect. It would be worth raising this to our support team so they can reset the mysql password for you.
Message 2 of 3
(246 Views)
12-02-2009 9:45 AM
Just make sure that they don't refresh the database component (as happened to me) and hey presto - no more database!
Message 3 of 3
(246 Views)
- Everything else
