Connect to SQL
- Everything else
- Re: Connect to SQL
Connect to SQL
07-04-2011 9:27 PM
I'm sure I'm being dim, but can't work this one out!
I'm trying to use php in my ccgi space to connect to my SQL database, but I can't seem to make it work.
I'm currently using the following - I'm assuming it's the $server definition that's not correct but I don't know what to change it to!
$server = "rumpus";
$user = "greenofashbourne";
$pass = "password";
$database = "greenofashbourne_pn";
$connection = mssql_connect($server, $user, $pass)
Any help appreciated.
Thanks,
Stuart
$server = "rumpus";
$pass = "password";
Thanks,
Stuart
Message 1 of 6
(1,014 Views)
5 REPLIES 5
Re: Connect to SQL
07-04-2011 9:34 PM
The password is not the same as your account password, it is created when you activated MySQL and included in the email that is sent to you after activation.
If you can't remember it just disable MySQL and enable it again and wait for the email with the connection details.
Message 2 of 6
(413 Views)
Re: Connect to SQL
07-04-2011 9:37 PM
Amazingly, I have got the email with the database password on it - so I know that is correct (and I can log into the SQL through PHPMyAdmin - I just can't use it with a .php file called from ccgi.greenofashbourne.plus.com).
Thanks,
Stuart
Thanks,
Stuart
Message 3 of 6
(413 Views)
Re: Connect to SQL
07-04-2011 9:40 PM
try rumpus.plus.net
Message 4 of 6
(413 Views)
Re: Connect to SQL
07-04-2011 10:15 PM
Thanks! That worked (after also spotting that I needed to change mssql to mysql!)
Cheers,
Stuart
Cheers,
Stuart
Message 5 of 6
(413 Views)
Re: Connect to SQL
07-04-2011 11:18 PM
"rumpus" alone would probably work after correcting the name of the "connect" function.
David
Message 6 of 6
(413 Views)
