Configuring a BT SmartHub 6A as an Etherner Switch/Router
ejs
Aspiring Hero
Fixes: 25
Re: Configuring a BT SmartHub 6A as an Etherner Switch/Router
What I said earlier about connecting LAN ports together, the main point was really about not using the WAN port, so that your Internet connection is not going through both routers and having double NAT.
The stability problem on that G.fast thread seems to be about connecting two routers together in a different way, trying to use one as a modem, but since they don't have a bridged modem mode, it doesn't work very well.
Fixes: 480
@ejs
Just to confirm, I have had LAN ports connected together. The FTTC Smarthubs do not have a WAN port.
typonaut
To get a cheap WAP I bought a Linksys E1200 router from eBuyer - £19.95. For some reason it took about two weeks to get here!?
Anyway, I find Linksys stuff generally reliable, if a bit unpredictable in the interface. However you can usually get there in the end. In this case I eventually realised that I had to "save", before a restart… Range is not great, but you can put them anywhere you can run an ethernet cable (which isn't a problem for me). In this case it is a genuine router, so you can have a different subnet on the wireless side. Also has some more sophisticated settings like being able to check access privileges via a server, so essentially you can control access on an individual basis rather than having one password for all users.
There's a slightly cheaper model, the E900 for £15.95 and there are obviously more expensive models too.
Only wireless N on this router. For me this isn't an issue, because I find I cannot get AC (5GHz) over any distance in this flat anyway. May be possible to link a web of these devices to provide continuous/seamless coverage over a wider area, without switching access points - haven't really looked into it.
Minor gripes: status lights are really well hidden (it would be nice to see some kind of activity without having to pick it up, but then it is also quite unobtrusive), no mounting options (there are no screw slots on the back, so you can't hang it on a wall - you'd have to get the velcro out).
