Configuration of home WIFI with second line and router
brico
Hi all,
I have a complex house but using BT Wholehome discs (6 of them) I have managed to cover every part of it. I have one internet line on a 65mb service from Plusnet.
In order to increase bandwidth, I have ordered a second phone line into the house, with a second router and service.
Is there any way to configure the lines/routers so that all users can use the existing Wholehome configuration to access both lines.
I'm ideally looking for both increased bandwidth and better resilience if there is a failure on one of the lines.
Any experiences with using 2 lines into the same property?
Many thanks
9 REPLIES 9
Fixes: 124
Re: Configuration of home WIFI with second line and router
you need to investigate load balancing.
brico
Yes I agree.
But at the moment it seems that I just split the load between 2 routers. But there must be a way to load balance and share the two lines, maybe needs more hardware?
My wholehome network is sound and provides access to all devices throughout the house. They don't care where the internet service comes from.
I will have two internet lines and two routers. How to connect the wholehome network to both of these? And balance the load? Double bandwidth but where is the load balancing done?
Fixes: 124
There are devices which allow for your solution, hence my suggestion to do some research
You will need a router which allows for this.
Take a look at https://www.draytek.co.uk/products/routers/load-balancing-routers
Hope he doesn't mind but Super User @MisterW might give some help
Dan.
Fixes: 528
Yes, one of the draytek routers should do the load balancing. You should be able to connect one of the fttc lines directly to a vdsl input but you'll need a separate vdsl modem  to connect the 2nd fttc line to the wan input.
Not sure how the whole home wifi works though, if it connects to the routers lan as a wireless ap then it should just work, since there is only one router  and thus only one lan
Fixes: 457
Moderators Note
This topic has been moved from Broadband to Everything Else
Mustrum
Fixes: 81
Have a look at the Draytek router comparison chart, they don't come cheap though.
https://www.draytek.co.uk/products/comparison/router-comparison
brico
OK so I have purchased a load balancing router - a TP Link model TL-R470T+
The reviews on Amazon etc indicate that some people have been successful in combining the 2 lines to work with the router.
Is there anyone in this community that has succeeded - and can advise?
Many thanks!
Fixes: 528
Whilst the R470T does appear to support load balancing, it is just a router. You will need a VDSL modem for each FTTC line in front of the r470T. In addition the R470 is not very future proof , it only has 100Mbit ports.
markhawkin
All Star
Fixes: 18
@brico I may be too late to this but, for example, a Draytek 2860 (available second hand for a few 10's of pounds) will do what you want.
As you have WiFi coverage you just need a version without WiFi and follow Draytek's load balancing instructions.
Ir works fine, I've done something similar and the bandwidths add.
