Cisco VPN not working
- Everything else
- Cisco VPN not working
06-02-2019 10:40 AM
Hi everyone,
I'm having some issues with accessing external websites when I connect to my work VPN. Our Intranet, local resources and drives work fine, but web pages outside of our network time out, (ERR_CONNECTION_TIMED_OUT and DNS_PROBE_FINISHED_NXDOMAIN). I am able to connect fine using mobile tethering (with Three) so the problem appears to be with Plusnet.
I am using Cisco AnyConnect 4.2.04018, not willing to disclose the company on the forum but would do so in private if needed.
Any help would be appreciated as I am getting quite frustrated trying to fix this and would be tempted to switch provider as another member of my team has done this and no longer has this problem with Sky.
Extra info:
Steps I have tried that have not helped:
- Tried changing from Plusnet automatic DNS to both Google DNS and OpenDNS to no avail, so returned to automatic DNS.
- Turned modem/router off for 90 minutes to attempt with a new IP
- Purchased a static IP address as this has helped others but not me (have been provided with one starting 81.174.x.x)
- Connecting directly via LAN cable to both home router (Asus) and through modem.
- Running entire router through NordVPN first and using their DNS (I don't use this usually, but was making sure to try everything I could think of)
- Set broadband firewall in members centre to off
I have also been trawling these threads and tried solutions in each, but these have not helped either.
- VPN connection lost today - https://community.plus.net/t5/ADSL-Broadband/VPN-connection-lost-today/m-p/1483172#M318357
- VPN connection - https://community.plus.net/t5/Fibre-Broadband/VPN-connection/td-p/1508652
- VPN IPsec blocked? - https://community.plus.net/t5/Fibre-Broadband/VPN-IPsec-blocked/m-p/1487743#M67199
- VPN not working - https://community.plus.net/t5/Everything-else/VPN-not-working/td-p/1555802
- VPN nightmare - https://community.plus.net/t5/Fibre-Broadband/VPN-Nightmare/td-p/1597358
Re: Cisco VPN not working
06-02-2019 10:50 AM
If I understand correctly the VPN is working, but only addresses within the far end network are accessible?
It may help to enable split tunneling in AnyConnect (if your client allows it) so that only requests to addresses in the remote VPN range are sent over the VPN and other requests are sent over your Plusnet connection.
Otherwise, another thing to check is what your PC's DNS is set to once you have an AnyConnect connection open. AnyConnect may be changing that to use the far end's DNS, which may only resolve addresses local to that network?
I use AnyConnect (and other VPNs) without problems, so it is possible (but I don't use a Plusnet router).
06-02-2019 11:14 AM - edited 06-02-2019 11:42 AM
That's correct, I can access our Sharepoint Intranet site and HFX system which can only be accessed from within our network. I can also access our network drives. However external websites, including our website CMS which is set to only allow access from internal connections, do not work for me.
Unfortunately the majority of options are disabled on my system as they're locked down by the corporate network. The best I have are the options in the Cisco client (see below). I have tried various combinations of these to no avail but I'm not sure how much of a difference they'd make anyway.
Cisco VPN options:
- Allow local (LAN access when using VPN (if configured)
- Disable Captive Portal Detection
- Block connections to untrusted servers
That's why I'd purchased the static IP, I'd read that having it in a certain range can cause this issue, but it doesn't appear to have helped.
Thanks for responding so quickly by the way, appreciate it.
Edit : added Cisco options
06-02-2019 12:02 PM
Moderators Note
This topic has been moved from Fibre to Everything Else
06-02-2019 1:39 PM
Would you mind sending me some details via PM so I can get that (Along with the other info you've provided on this thread) passed over to our Networks team to look in to further and see if there's anything we can do to help.
Thanks.
06-02-2019 1:50 PM
Thanks Harry, I've sent you a PM with that.
06-02-2019 2:09 PM
07-02-2019 1:32 AM
What do your own IT guys say about this issue?
In my experience of secure corporate VPN, whilst the VPN client is up, all traffic from the client is routed over the VPN and thereby permitted external connection is controlled by the remote network.
Such implementations intentionally inhibit the possibility of "pulling" corporate data and then sending it out via a non-VPN connection.
